65 mph spree build
65 mph spree build
let me start by posting this link in case everyone is not caught up...
viewtopic.php?f=1&t=20784
well I am pretty much done with the build. It is pretty scary past half throttle bc the spree just doesnt feel stable at all; mainly in the front end. I know a big part is due to the sidecar pushing it from an akward angle but if I dont mash the throttles and keep them in sync its quite smooth. (yes there are two throttles and 2 kill switches). The side car is basically set up like a gokart. 6.5hp honda 4 stroke with a torque converter. this scooter does wheelies like its nothing (and it must look funny seeing a scooter with a sidecar doing wheelies around town). I dont have any pics of the frame being welded b/c i didnt have a camera. Most of the other pics I took while building it were taken with my phone cam so sorry for the crappy resolution. ill start with these pics
- DSC_2111.JPG (204.03 KiB) Viewed 10886 times
- DSC_2118.JPG (234.47 KiB) Viewed 10886 times
- DSC_2110.JPG (252.19 KiB) Viewed 10886 times
Re: 65 mph spree build
here is the second throttle and kill switch. The sidecar is detachable from the scooter and only takes a few minutes to remove. Also the entire body of the sidecar pulls off its frame so its super easy to work on.
- DSC_2123.JPG (167.02 KiB) Viewed 10878 times
- DSC_2116.JPG (225.72 KiB) Viewed 10878 times
- Trafficjamz
Dangerous
I will give you props for creativity ....but I would never get in to that death trap.
So does it go 65mph?
How does the dual throttle thing work?
by the way, the pic with the motor exposed is with the rear cover off. normally you cant see the motor...
it has the power and gearing to do 65 but I am not brave enough for that yet. I have been considering putting it on a dyno to prove its capable (in terms of power and gearing). dual throttles work great b/c depending on if the sidecar is empty or has a passenger you can adjust.Trafficjamz wrote:Dangerous![]()
I will give you props for creativity ....but I would never get in to that death trap.![]()
So does it go 65mph?![]()
Some more info regarding build cost.
scooter-$75 (blown motor)
big bore kit- $120
side car (metal, wood, hardware, wheel, axle, bearings etc)- roughly $200
I already had the other motor and torque converter so I did this entire project for around 400.
- Trafficjamz
B-Nasty wrote:by the way, the pic with the motor exposed is with the rear cover off. normally you cant see the motor...
Yes......the undetectable "power adder"
Can a person actually ride in the side car?
Does the side car wheel have brakes?
I never said power adder....I said "power source"Trafficjamz wrote:B-Nasty wrote:by the way, the pic with the motor exposed is with the rear cover off. normally you cant see the motor...
Yes......the undetectable "power adder"![]()
ya it works great with a passenger and the sidecar does not have brakes but it stops great with just the spree brakes. I was anticipating a problem with braking but it works great as is
- Trafficjamz
When this contraption is "doing wheelies like nothing" What wheels come off the ground?
It it really a wheelie, or does it just tip slightly back and to the left?
I would be willing to bet that the top speed has not increased at all from this side car mod.
I still can't wait for you to prove us all wrongIn his previous BS post B-Nasty wrote:well I got the hardest part done last night. Spent about 6 hours working on it. Waiting for a few more parts then it will be ready. I am pretty nervous about doing 65 on a spree...I just dont think it will be stable at that speed.
but I cant wait to prove yall wrong
it pulls the front scooter wheel off the ground and slams the back of the sidecar frame in the ground...its not just a tilting thing.Trafficjamz wrote:When this contraption is "doing wheelies like nothing" What wheels come off the ground?
how much are you "willing to bet"?
- Trafficjamz
Willing to bet That this setup will not add any top speed (above 35mph)
Willing to bet That this setup will never reach 65mph
Willing to bet That it will not be as fast as my scooter (top speed)
Willing to bet That it would never beat any of my scooters in a race.
Pick one.
Pick one.
Interesting but i'm speechless.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- Trafficjamz
???B-Nasty wrote: it pulls the front scooter wheel off the ground and slams the back of the sidecar frame in the ground...its not just a tilting thing.
The side car wheel is in the middle and to the side of the other 2 wheels.
Doesn't the rear wheel stop it from wheelies?
I simply must see some video of this thing in action
what happens when only one throttle is applied?
Is there any suspension on the side car? Can you lean into corners at all?
If you lean too far right will the side car lift?
Even if the sidecar can go 65, the stock gears in the 2stroke will act as a speed limiter. You can only turn so many rpm before you just can't get any more air through the engine. At that point the other engine will be dragged down by the "main" engine. I think it looks fun, dangerous, and incapable of 65mph.
Kudos for creativity though. I'd love to try some doughnuts on that thing
Ol' Red
Broken...
Spreeio
1987 Spree
With af16e powah!!!!
Broken...
Spreeio
1987 Spree
- swimmingfree
i hope you dont get hurt by that thing .. i see lots of ways thing can go wrong ..with two motor and one that can go a lot faster then the other ...the twist on that thing going to snap it back in to two peaces .. i hope you not have some one in the side car when it happens ..
i do like the side car alot .. the motor in not so munch ..
ill give you that you made a stock spree go 65
- Trafficjamz
Right on spreetardThe spreetarded one wrote:You can only turn so many rpm before you just can't get any more air through the engine
