speedo cable compatibility
the0captain
Post by the0captain »
Im needing a speedo cable for my 87 elite but it seems hard to obtain one. Doe anyone know if a speedo cable from something else work?
sanjuro
Re: speedo cable compatibility
Post by sanjuro »
Any of the '94-2001 Elite speedometer cables should work.
the0captain
Well an 88 speedo cable isnt nearly as long as an 87
87 on right, 88 on left.
That's one of the tough parts about cable compatibility. Different routing and plastics changes often triggered cable changes. Honda's part number coding is a clue they differ, but it's no way to tell what changed. For Brake cables, lever side and brake side cable ferrules vary in dia too.
-- Call to all --
Help out the next guy, measure your cables whenever you have them out, using reference measurement points detailed in the link below:
wiki topic: Cable Dimensions .
