80mph set up?
HammahDIO808
80mph set up?
Post by HammahDIO808 »
I need some advice on how to hit 80mph?
I recently messed up my 82 bore. So I was think of buying a 72
Polini contessa?
Specs on motor.
-Dd50 block
-Ruima 44.4 ministroke crank
-boost and intake is ported.boost is matched to a polini corsa boost.
-7.4 gear
-lighten mag
-ncy teflon insert pulley. With 42g weights. (9x3, 5x3)
-daytona 2 ramp plate.with ncy guieds
-zx trans with ncy torque plate
-ncy clutch. 3k clutch springs and 1500 center
-ncy clutch bell
-stock drive face
-ct black mani.stock reeds
-30 oko carb. 135main 52 pilot.
-1st gen pg long
-racing cdi
I'm around 185lbs.
Lmk wat I need to change.
kingkamehameha
Re: 80mph set up?
Post by kingkamehameha »
Ho cuz your jets are wayyyy to small. Consider using a 28mm or a 26mm carb instead. Your gonna need bigger jets ffor that carb. Oh and 80mph is out o reach ffor even the almighty corsa. A stroker might be able to push taller gears to get that top speed. Your trans set up is all wrong too. You can't run 9s and 5grams together. You can only go two grams apart on the weights. And mabey try polini naturals with the 1.5k center. Good luck I would hit up red eft performance he has some good malossi bores for cheap
HammahDIO808
Re: 80mph set up?
Ok. I have a 28 keihen on the side. Wat jets you think I should runs on that. And what kind on weights and springs should I run?
kingkamehameha
Re: 80mph set up?
Everyone is different and has different riding styles. So its best to try different set ups. You'll like the polini naturalls with the 1.5k its a real nice set up. Try 6-8gram weightts and play around with them. If your breaking in a new bore and the boostt port is matched I would suggest the needle clip in the middle and 138-142 main 52-55 pilot. Make sure to match boost port and after break in you can mabey move down to 135 main. Be sure to do correct plug chops.br8s
Re: 80mph set up?
80 mph on 7.5gears is a tall order. :surprise:
try 6.3:1 gears :imo:
a 654 belt will help with top speed (I don't know if this applies to a dd50 or not)
HammahDIO808
Re: 80mph set up?
Wat do u mean by polini natruals? 2k polini clutch springs?
bakaracer
Re: 80mph set up?
Post by bakaracer »
Trafficjamz wrote:80 mph on 7.5gears is a tall order. :surprise:
7.5 gears will do 80@10700 rpm with a stroker setup(107cc)
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
Re: 80mph set up?
I made this speed chart based on a dio not a dd50.......I don't know if the gears are the same.
I know a dd50 has a 12" rear wheel. :confused:
bakaracer
Re: 80mph set up?
Post by bakaracer »
dd50 is the same like a jdm dio. the kymco zx50 has the 12in rim
91 yamaha tzr 250r
bakaracer
Re: 80mph set up?
Post by bakaracer »
to the OP, asking a 72 to do 80mph is pretty much null unless you know how to port and tune to make that kind of power. not alot of guys out there can make a 72 go that fast. most of the guys that claim that they can in hawaii is full of it. most of them are kids under the age of 18 and pretty much all of them cant afford the tools to port the bore correctly and let alone how exactly how a 2 stroke works. they only know from watching someone else put a bike together or from stories being told. if you want a more realistic speed for a 72cc setup. shoot for 70mph.
91 yamaha tzr 250r
kingkamehameha
Re: 80mph set up?
True datt baka told like a wise man
bakaracer
Re: 80mph set up?
Post by bakaracer »
if you want a 70cc kit to do 80mph+ ,get yourself a horzontal minarelli engine and buy the stage6 r/t full kit. thats a 21hp+ kit that will get you to that speed. but look on spending over $1800 just for parts. you will get a record holding 1/8th mile sprint kit. stage6 holds that record for 70cc at a mid 7sec run
91 yamaha tzr 250r
veedubh20
Re: 80mph set up?
Post by veedubh20 »
What gear did use in Minarelli.
bakaracer
Re: 80mph set up?
Post by bakaracer »
veedubh20 wrote:What gear did use in Minarelli.
you can use a 9to1 gearset to go that fast . 80mph@13000rpm which is a very mild tune for that kit. with the r/t exhaust pipe and that kit, you can tune to 15k no problem and make about 24hp. that should be more than enough to get you to 80mph. or just spend about $500 and build a dio stroker 120cc and go faster.
91 yamaha tzr 250r
JJ Joseph
Re: 80mph set up?
Post by JJ Joseph »
HammahDIO808 wrote:I recently messed up my 82 bore. So I was think of buying a 72
Polini contessa?
There's no substitute for cc's, so I don't see downgrading -10cc to 72cc. You'll need every cc you can get to push your speed up when near the top of the range. You might find that it's clapped out by 8000rpm without the extra cc's.
