"top end rebuild kit"
terryc8171
- Goped
Lost all my compression on my Saturday ride. Looking to buy kit from VTCycles (http://www.vtcycles.com/vtc_plugins/e10 ... ct=1&cat=7). I'll grab another jet for the carb as well.
Looking for other opinions, advice on anything you would do to your scoot if you were making this repair.
'87 se50
'87 se50
'87 SE50
'87 NQ50
'87 NQ50
- SuprasNsprees
Re: "top end rebuild kit"
did you melt the piston , or score the cyl walls with dirt/debris ?terryc8171 wrote:Lost all my compression on my Saturday ride. Looking to buy kit from VTCycles (http://www.vtcycles.com/vtc_plugins/e10... ct=1&cat=7). I'll grab another jet for the carb as well.
'87 se50
while the link you posted doesn't work, I'd be looking at big bore kits if it were mine . these are always good times to do mods
'80 Puch Magnum MKII
'78 PA50 Hobbit
'78 PA50 Hobbit
- swimmingfree
terryc8171
- Goped
Thanks swimmingfree.
I haven't looked at the piston yet. Guess maybe I'd better look before I buy!
'87 SE50
'87 NQ50
'87 NQ50
If you have broken parts, be sure to clean out the bottom end before rebuilding the top end.
- swimmingfree
when you brake it down not let the piston bang around or turn the crank it may put a small crack in the piston that will show up when its running ..like what happen to me
By freeswimming at 2011-08-23
then you have to crack the case to get all the piston out of the block that's the only way to make sure you get all the piston out of there .. the allumun of the piston will get in the Bering and mess them up casing you a bigger problem .. there been a lot of people saying just turn it up side down and spry it out with carb cleaner that's not a good way to do thing ..
Always split the cases
DJ1
NEK MINNIT
Malossi
DJ1 54mph
dio gear swap in progress
living in chch NZ
earthquake central
NEK MINNIT
Malossi
DJ1 54mph
living in chch NZ
earthquake central
terryc8171
- Goped
Obviously need a new piston. Looks like part of the clip is still there. The cylinder needs work. Any suggestions appreciated.
'87 SE50
'87 NQ50
'87 NQ50
that looks like an improper c clip install that caused that.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
- swimmingfree
by the photo you have on here it looks like time for a bbk or see if someone has a use se50 top end for sale ..
bakaracer
i think your right the c clip came out..
bakaracer
terryc8171
- Goped
c clip was my guess as well. based on the cause, should the connecting rod be ok?
'87 SE50
'87 NQ50
'87 NQ50
double check the clearances on it. also clean out the engine case. by the looks of that piston, my guess is that there is metal pieces in there
91 yamaha tzr 250r
91 yamaha tzr 250r
terryc8171
- Goped
I'll have to read how to check the clearances and splitting the case. I don't have any specialty tools if that's required.
'87 SE50
'87 NQ50
'87 NQ50
terryc8171
- Goped
Found a used, complete top end I can see next week. Thanks for the help. If I need help with crankcase I'll search old posts.
'87 SE50
'87 NQ50
'87 NQ50
