1987 Honda Elite S w/ pictures 99.01%
Kolten
Post by Kolten »
I am in the process of restoring a 1987 Honda Elite s (SE50) with engine code AF05E. The piston I had measured three times, and am I tripping or did I forget how to use a ruler lol, because it measures 51mm with tons of extra material also on the casting of the cylinder jug(correction 01/04/12 the gaping tool has extra lines and that is why I was measuring wrong LOL). Sorry the picture quality on iPods suxx. I hooked up a sweet gel battery, and I could only get the horn to honk beep and tail light lights up when the key is on position, when I squeeze break levers brake light does NOT light up, turn signals do not click (flash) (correction: 01/04/12 got to get a new flasher unit), start does not turn starter motor (starter motor works had tested) (correction 01/04/12 :I cleaned the connection in the steering controls), CDI works had it plugged right into a 2005 SYM DD50. Rough guess I may need new controls, starter relay/solenoid PLEASE correct me if I'm wrong, umm... of course bulbs, regulator/rectifier not too sure if needed when horn works and tail light lights up. If anyone has got some 411 please help me out. This one will definately be a keeper when fully restored to factory, or maybe a 65cc refresh kit. 02/7/12 Met front end, bmx stem and bars, relocated fr turn signals, single headlight
Just got Legal today 01/2012, installed flasher relay today 01/18/2012, relocated turn signals 01/18/2012.
I'm at 99.01% So I can leave myself with options.
Nice Cases, and uncut
41mm cylinder
41mm cylinder
41mm piston
41mm piston
1987 Honda SE50 Elite S
2006 Honda NPS50S Ruckus
My Wife's 2005 SYM DD50 660ft 12.79 47mm bore
2008 JCL Gy6 155cc 78Mph Stock bore, +2.2mm Stroke Crank shaft.
2008 Kymco Top Boy Swap Gy6 170cc
2004 Honda Metropolitan Get Engine 60+Mph
1995 Honda CBR600F3
kingkamehameha
Re: 1987 Honda Elite S restore and piston size verification
Post by kingkamehameha »
Your trippin
Kolten
Post by Kolten »
kingkamehameha wrote:Your trippin
ok so I know the quality is bad but by judgement of picture what size piston is this. Some actual help would be most appreciated :)
(correction: LOL I figured the problem, wrong measuring tool :crazy: )
1995 Honda CBR600F3
evilone
Post by evilone »
Kolten wrote:The piston I had measured three times, and am I trippin or did I forget how to use a ruler lol because it measures 51mm with tons of extra material also on the casting of the cylinder jug.
I'm pretty sure 51mm is a little over 2 inches, you're nowhere near that.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Post by swimmingfree »
inch/mm CONVERSION CHART
25.4 to 1 inch
hope this helps
fastplastic
Post by fastplastic »
this is a joke plz follow link and buy tool......
http://www.harborfreight.com/6-inch-dig ... 47257.html
dun rite
Post by dun rite »
first download and study this. http://www.hondaspree.net/other/SE50_19 ... Manual.pdf it will be of great importance for your resto.
then download this one. ww.hondaspree.net/other/SE50_1987_Wire_Diagram.jpg
Also there is lots of info in the wikispreedia. ww.hondaspree.net/other/SE50_1987_Wire_Diagram.jpg
the headlight only works when the motor is running. as far as the elect. start it helps to have a multi meter for testing. could be bad wires, switches, connections, solenoid,
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
Charge the battery.
Kolten
Post by Kolten »
Bear45-70 wrote:Charge the battery.
Hey, Thanks to all. Ill be sure to take my time on this restore. It my first elite ever and 2nd 2T as well. My first is a DD50 that one is for my girl. We sold our cars to commute since we always in town (very busy).
Thanks for the info you all have given me and thanks to wikispreedia. Ill be sure to make a donation once everthing is squared away :thumbwink:
1995 Honda CBR600F3
Kolten
Post by Kolten »
fastplastic wrote:this is a joke plz follow link and buy tool......
Paid $3 for the scale
1995 Honda CBR600F3
Kolten
Post by Kolten »
The gauging tool had some few more lines than needed not intended for measuring much, the inches and centimeters were accurate though :)
1995 Honda CBR600F3
Kolten
Re: 1987 Honda Elite S restore w/ pictures and progress
Post by Kolten »
Here is a picture of the goodies I got and a couple pictures of the Elite partially disassembled.
Thankfully the panels were there but would like to find that under cowl, not complete without one on my ride
Elite in the trouble shooting process: <br />-Starter motor turns with starter button yeah!<br />-Tail light turns on when key is on position, brake light turn signals and display light not working yet.  Need to read that manual :idea: <br />-Cleaned and verified functionality of control switches <br />-Using Sym DD resistor, regulator, and battery for tests
The goods :)
The goods :)
1995 Honda CBR600F3
boy you need to do better photo .. hole the boton hafe way down till the green light come on then push the reat of the way down .. or do something cant see munch to fuzzy and the photo do help a lot.. some times youll ask what is this ans we may say a fuzzy kitten because thats what thay look like..
on to other things .. looks like a nice toy you got there ..
Kolten
Post by Kolten »
swimmingfree wrote:boy you need to do better photo .. hole the boton hafe way down till the green light come on then push the reat of the way down .. or do something cant see munch to fuzzy and the photo do help a lot.. some times youll ask what is this ans we may say a fuzzy kitten because thats what thay look like..
Dude I know right, the picture quality of my Itouch suxx when used at night and poor lighting. Ill get to re-posting them pics, and take them during the day :idea:
1995 Honda CBR600F3
what its 3 am there now i think your 5 hours behind me .. i for got about that
