pulling wheelies
molokai808
pulling wheelies
Post by molokai808 »
my cousin wants to no how to tune his bike foa pull wheelies? does he need to change weight? or his clutch foa a snappy throttle response? oh an his bike screems befoa taking off what could that be, reeds going out? let me know? :thumbwink:
Re: pulling wheelies
So your cuz is stupid huh? Make sure he does not wear a helmet and you will own his bike soon. :crazy:
SuprasNsprees
Post by SuprasNsprees »
I still don't understand why none of the Hawaiian members on any of the other boards i'm on talk like this .
can you imagine Swimmingfree being one of these guys ? lol no offense buddy
'80 Puch Magnum MKII
'78 PA50 Hobbit
Post by swimmingfree »
not a big deal ..i no my spelling is bad
i hope this guy figer out how to do this ..
but he will not have the top speed he had you need tork to walk the bike...
molokai808
plz no negative comments, we jus need sum help hea were not trying to be stupid we jus need help.s*** if u needed help an i had the answer i would give it to u so no ack like we no the answer to the question. if u not going help dont say s***, keep it to yourself,
you did not give us a nuff info ..... how minny cc is the bike ??? what motor dose it have ?? whats been done to the motor??? dose it get close now ???? what is the gear is in it ?? all this is good to no if you want to do this !!!!
im sorry if we have a hard time reading you..
molokai808
right now he dont care about the top end he jus like learen how to keep it up foa now!!! but sorry if i sound like an * on the last post i jus didnt like the reply. i not trying to be a bad person in jus trying to take in the most i can from everyone...
molokai808
he has a 72cc polini corsa 8.1 gearing pg long 28 oko um i think he get 45g an the clutch is a koso but the clutch is sum what good.
Skill, which he does not have. I've seen guys wheel stock Sprees. Quit whinning like an 8 year old little girl.
i wood bet if he went back to stock or 12/1 he cood not keep the front end down but if he 300 lb it my not work as well but his top speed will be down to 30 or 40 but that a guess... if its close i wood drop the roller down by 3 to 6 grams or change the 3 clutch springs or go to a smaller back tire 2.5 .. you may have to do one or more of these..
molokai808
ok i going tell him about the set up an go fron there.....
im not saying you need to do all but some yes..
gixxer1000chad
Post by gixxer1000chad »
my stock elite 50 will do wheelies all day long..i know it's a spree..but with all that he has done to it it should wheelie no problem.. Sit far back on the seat twist the throttle to where the clutch starts to engage and yank up on the bars while leaning back a bit. Also have one or 2 fingers on the rear brake to set you back down if you come up to fast..thats the key is controlling how fast you pop it up to the balance point and the it's throttle control and brake ofter that...good luck and don't get too aggressive with it or you'll flip backwards and get hurt..
i bet mine is slower!!! now what??
gixxer1000chad
as far as the noise..it could be several things. Belt , clutch, bearings.etc.. Those also could make a huge negative impact on performance if the are worn out...you wouldn't be getting all the power to the ground...
molokai808
ok ill let him know... thanks foa the info....
