89 Elite R - my first build
89eliteR
Re: 89 Elite R - my first build
Post by 89eliteR »
Lets play a game of what goes where!
Fist off, there are 2 lines that connect to the bowel of my carb, where do they connect to?
Also see one on the front of the carb without a hose, at the bottom of the bowel? do I connect a hose to it? and where does the other end go?
Now there is a nipple for the intake, I think one of the lines from the tank go here, but which one?
im pretty sure the main gas line goes to this brass end here, by all means correct me if im wrong.
bonesv
Post by bonesv »
Nice job getting it buttoned up! I like it!
Where did you get the carb. from and what is the brand name and size?
You are correct about the brass fitting on the carb. and the nipple on the manifold is for the vacuum line.
Just suck lightly on one of the lines, when gas comes out of the other line then you have the vacuum line.
I'm not sure about the other lines, they are probably drain lines and/or vent lines. I would consult the seller about those. :thumbwink:
Happy Trails! :coolcruise:
tazland001
Post by tazland001 »
The intake has a nipple for the vacuum line. The rest are for drain and vent.
Taz
89eliteR
Post by 89eliteR »
One thing to clairify, on the part that comes out of the tank has 2 lines. One goes down the other comes out on the side. I belive the one on the side goes to the brass nipple on the carb, and the one that goes down is the vaccume line?
Post by swimmingfree »
yes!!!!!!!!!!
looking good...
305elite
Post by 305elite »
The two lines that come out the gas tank one is fuel and the other is vacuum...fuel goes to the brass nipple and the vaccum goes to the barb on the manifold...as for the one on the bottom of the bowl just leave it it is nothing...good luck and hope this helps
01 Elite Sr
72cc Polini Corsa
21mm Pwk carb
V8 Typhoon exh
8:44:1 gears
305elite
Post by 305elite »
This looks like tazmans 21mm pwk carb package....if it is you will like it i just reacently installed the same setup on my new polini corsa build amd i was really impressed its a nice setup
01 Elite Sr
72cc Polini Corsa
21mm Pwk carb
V8 Typhoon exh
8:44:1 gears
89eliteR
Post by 89eliteR »
It is Taz's kit. Just waiting for my variator to come in and ordered a new belt and should be able to do some test runs in a week or so
305elite
Post by 305elite »
nice....so you got all the lines figured out?...what vari did you decide to go with?
01 Elite Sr
72cc Polini Corsa
21mm Pwk carb
V8 Typhoon exh
8:44:1 gears
89eliteR
Post by 89eliteR »
ordered a stock ruckus vari from a dude off here. as far as the lines i might do that tonight. If i do i will post pictures for conformation.
305elite
Post by 305elite »
Sweet...post pics forsure...good luck
01 Elite Sr
72cc Polini Corsa
21mm Pwk carb
V8 Typhoon exh
8:44:1 gears
89eliteR
Post by 89eliteR »
Well after referencing pictures of the old setup i think i got what goes where:
Mystic
Post by Mystic »
Looks good to me. I bet you are ready to get this puppy rolling huh? why not put her back together with the stock vari and weights and take her for a spin?? I know I would :D
89eliteR
Post by 89eliteR »
Mystic wrote:Looks good to me. I bet you are ready to get this puppy rolling huh? why not put her back together with the stock vari and weights and take her for a spin?? I know I would :D
sold the ramp plate from the stock vari otherwise I would have. My vari could be here any day now tho.
305elite
Post by 305elite »
looking good everything seems to be in place
01 Elite Sr
72cc Polini Corsa
21mm Pwk carb
V8 Typhoon exh
8:44:1 gears
