1980 Honda Express 2?
Mormonmopedmaifa
Post by Mormonmopedmaifa »
Anyone know anything about a 1980 honda express 2 moped... My friend is having a real struggle with it.
What it's doing is it takes gas right in but spews it right out the overflow on the carb. Then it's flooding before we even give it gas. Like when we get it started (takes about an hour) it's good to go, but if you let it sit, you're boned. Anyone? Ideas?
M>M<M
THE MAFIA STRIKES AGAIN!!!
ALMOST running spree!!!
85stroka
Post by 85stroka »
sounds like the petcock is stuck wide open,take the fuel line that leads from the tank to carb off at the tank and see if gas is constantly coming out,if it is then the petcok is leaking,if it aint then check the float in the carb.
But either way gas from the tank should not be constantly running with the bike not running!
Remember,everyone is human,even if there stupid!
Mormonmopedmaifa
Yeah the petcock is kinda messed up, it drips when its on the off position but we got it running now (cleaned the carb and all the jets) but the whole "Doesnt stop spewing gas" thing is still wrong... It doesnt flood when its running but you kill that thing and its all gate aflow. So yeah the float makes alot of sence, its just I didnt want to break something that wasnt broke without someone else's input.
M>M<M
85stroka
Post by 85stroka »
oh,yours have a manual petcock- the kind you turn to off/on /res?
Sorry thought it was vacuum type!
yeah sounds like float valve is stuck open
darat
Post by darat »
umm
MySpree
Post by MySpree »
yes thats how my express is... was... i got a new valve adn cleaned the carb adn it was good.
darat
Post by darat »
umm ur express dont even work what are u going to do push it down the street...
MySpree
Post by MySpree »
uhh yea it do it always has worked. ok my aero runs yet thene ingine isnt in right now ( engine is getting galss beaded. the spree runs but i have no way of starting it unless i use a drill...( just found out why the starter wont work) and now the express is done engine is in and everything
darat
Post by darat »
Yeah ok
mopedman
Post by mopedman »
ok that is why it is laying around in parts
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
darat
Post by darat »
sry for geting off topic ...
MySpree
Post by MySpree »
when u came over it was as of 3 days ago is together
Mormonmopedmaifa wrote:Yeah the petcock is kinda messed up, it drips when its on the off position but we got it running now (cleaned the carb and all the jets) but the whole "Doesnt stop spewing gas" thing is still wrong... It doesnt flood when its running but you kill that thing and its all gate aflow. So yeah the float makes alot of sence, its just I didnt want to break something that wasnt broke without someone else's input.
You need a new float valve, may a float too (see if it's still good.)
Run a fuel filter to keep the float valve seat from getting crud in it.
