1989 Honda Elite LX Electrical Problems
Re: 1989 Honda Elite LX Electrical Problems
mc1092 wrote:Ok so can anyone tell me how the whole engine kill works from the killswitch or ignition key turned to the engine being turned off, where the electricity flows?
The engine kill wire is black with a white stripe.
The black/white wire comes from the cdi and goes to the key switch, then goes to the kill switch on the handle bars.
If this black/white wire gets shorted to ground (always a green wire), the cdi stops sending pulses to the coil.
Both switches in the "run" position are open (not shorted to ground).
mc1092
Post by mc1092 »
Ok my problem still persists. Is it possible for CDI unit to start the scooter and keep it running but fail to kill the motor when I flip the killswitch or turn the key off?
mc1092 wrote:Ok my problem still persists. Is it possible for CDI unit to start the scooter and keep it running but fail to kill the motor when I flip the killswitch or turn the key off?
Yes, but extremely unlikely. To check that just short a green wire to the black/white wire. If the scooter shuts off it ain't the CDI. Oh and be d*** careful with that black/white wire, it will hurt like * and possibly numb your arm for awhile.
mc1092
Post by mc1092 »
Thank you all for your help. Turns out the old CDI unit was faulty and unable to send the kill so with a new one purchased, I was able to turn the scooter off via ignition switch and killswitch.
bonesv
Post by bonesv »
Thanks for reply with solution. This is most valuable to all of us and safe holidays. :smile:
