spark plug question
305elite
spark plug question
Post by 305elite »
162 miles in to my break in let me know what you guys think...polini corsa..21oko....32:1 premix
01 Elite Sr
72cc Polini Corsa
21mm Pwk carb
V8 Typhoon exh
8:44:1 gears
bakaracer
Re: spark plug question
Post by bakaracer »
Way rich!!
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
305elite
Post by 305elite »
you thinkits to rich for break in?.....i have a 102 main jetin right now what do you sugest
01 Elite Sr
72cc Polini Corsa
21mm Pwk carb
V8 Typhoon exh
8:44:1 gears
bakaracer
Post by bakaracer »
I don't think that's a proper mainjet plug chop as your still breaking it in unless your breaking it in at wot or more than 1/2 throttle on a constant on your ride? If your less than 1/2w throttle on your ride, its a pilot jet and needle that's running rich.
91 yamaha tzr 250r
bakaracer
Post by bakaracer »
What does the temp gauge read when your riding?
91 yamaha tzr 250r
305elite
Post by 305elite »
your right it is not a proper plug chop.....i havent went over half throttle yet being that i am in the break in process still....the highest the temp has gotten was 286...but at a stop lightt it drops
01 Elite Sr
72cc Polini Corsa
21mm Pwk carb
V8 Typhoon exh
8:44:1 gears
305elite
Post by 305elite »
so do you think i should leaveit untill im done breaking it in or down jet some now?
01 Elite Sr
72cc Polini Corsa
21mm Pwk carb
V8 Typhoon exh
8:44:1 gears
bakaracer
Post by bakaracer »
Your 280deg temp right there is a sign its rich. You can lean the needle 1 clip . I bet it burbles a lot when your just getting on the throttle? What do you have the air/fuel screw set at? Where is the needle clip position right now?
91 yamaha tzr 250r
305elite
Post by 305elite »
it burbles A LOT...my af screw is only a half turn out and the clip i have no idea it is where it is from factory so imguessing the middle....after break in period what is a good running temp
01 Elite Sr
72cc Polini Corsa
21mm Pwk carb
V8 Typhoon exh
8:44:1 gears
bakaracer
Post by bakaracer »
Yeah that air/fuel screw is in way to far.What size pilot jet in there? You can get the temps in the low 300's for breakin. At wot you want to see around 385
91 yamaha tzr 250r
305elite
Post by 305elite »
what should i put the screw at?...the pilot is 42
01 Elite Sr
72cc Polini Corsa
21mm Pwk carb
V8 Typhoon exh
8:44:1 gears
There are no hard numbers for idle mixture screw settings. You adjust for the highest idle speed possible, then adjust the idle speed screw for an idle of 1800 RPM.
Pete M
Post by Pete M »
Looks like a very cold plug
89 Elite E
deuce217
Post by deuce217 »
What temp gauge do you guys suggest? I would like it to be hard wired not just a BBQ type. Thanks
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
bakaracer
Post by bakaracer »
The trailtech tto temp gauge is a cheap good one. Plus its small to put anywhere. You can get one of those for about $45 shipped
91 yamaha tzr 250r
