spark plug question
deuce217
Re: spark plug question
Post by deuce217 »
bakaracer wrote:The trailtech tto temp gauge is a cheap good one. Plus its small to put anywhere. You can get one of those for about $45 shipped
Right on I checked their site out. I guess the spark plug one would be best for a spree?
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
bakaracer
Post by bakaracer »
yeah. those gauges work real good. got them on 3 of my bikes. and used it on my race scoot for the last 2 years now.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
deuce217
Post by deuce217 »
bakaracer wrote:yeah. those gauges work real good. got them on 3 of my bikes. and used it on my race scoot for the last 2 years now.
Have you had any trouble or heard of a spree throttle freezing up do to cold weather? Mine did this tonight for the 2nd time. I drove 5 miles with the throttle pinned and would regulate speed with brake and kill switch, ran a few stop signs and made it home. Last time it happened about 1 mile from home so I hiked back... Thanks for any input.
50mm BBK (tai)
V-8 pipe
maddog
Post by maddog »
BTW a temp guage depends on what gear ratio you run, also what plug heat range you run- westack analog is the best.
maddog wrote:BTW a temp guage depends on what gear ratio you run, also what plug heat range you run- westack analog is the best.
Your really have no clue what you are taking about do you?
deuce217
Post by deuce217 »
Please explain how the gear ratio corresponds to the temp gauge. I dont understand how it would.
50mm BBK (tai)
V-8 pipe
bakaracer
Post by bakaracer »
You might have to some how get oil in the cable housing. Moisture must have built it inside so when it gets down to freezing level, it ices up and rust begins to form inside. Its bit of a pain and time consuming.
91 yamaha tzr 250r
Jahden
Post by Jahden »
baka, did you remove the crush washer from the spark plug for the temp gauge?
bakaracer
Post by bakaracer »
I run both. I do take the crush washer off to slide the sending unit ring on then put the crush washer back on
91 yamaha tzr 250r
deuce217
Post by deuce217 »
bakaracer wrote:You might have to some how get oil in the cable housing. Moisture must have built it inside so when it gets down to freezing level, it ices up and rust begins to form inside. Its bit of a pain and time consuming.
Thanks, I put some tri-flow down there the first time but did it 1/2 a s s so I will acually remove the line and force it all the way down until it leaks out the bottom...
50mm BBK (tai)
V-8 pipe
