Ramp plates
Jahden
Ramp plates
Post by Jahden »
Which would you choose, daytona or Kelli? Is there any pros and cons with the two?
bakaracer
Re: Ramp plates
Post by bakaracer »
they both work good. angle wise the same if not real close. the only way you would really tell is if you tried both on a dyno to see the different torque curves
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
Jahden
Re: Ramp plates
Post by Jahden »
Baka, I'll just leave my daytona I'n then lol.
And thanks for the temp gauge info :smile:
bakaracer
Re: Ramp plates
Post by bakaracer »
just round the edges off of the ramp plate so it doesnt eat up rollers
91 yamaha tzr 250r
Jahden
Re: Ramp plates
Post by Jahden »
Ouch, is that the cause of having flat spots on the weights?
Thatll be my task for my ped
maddog
Re: Ramp plates
Post by maddog »
daytona is made of a softer metal compound so don't overtorque it, the center will wear....
onna spree
Re: Ramp plates
Post by onna spree »
Good info, I much prefer your advice over bear scat's ranting. :drama:
Re: Ramp plates
onna spree wrote:Good info, I much prefer your advice over bear scat's ranting. :drama:
Once again proving you can be too stupid to learn.
maddog
Re: Ramp plates
Post by maddog »
steve at vt cycles gave me that info- bear who gives you your info= my old posts :smile: :smile: :smile: :smile: :smile:
Re: Ramp plates
maddog wrote:steve at vt cycles gave me that info- bear who gives you your info= my old posts :smile: :smile: :smile: :smile: :smile:
You could repeat anything said by anyone in scooterdom correctly if your life depended on it. You have to BS everything just like you are BS about
maddog wrote:steve at vt cycles gave me that info...............
and I wouldn't use your posts, old or new to wipe my maddog and anybody that does is to stupid to ride a scooter much less work on one.
niftyman
Re: Ramp plates
Post by niftyman »
This is coming from the guy who has trouble changing a spark plug
DJ1
NEK MINNIT
Malossi
DJ1 54mph
dio gear swap in progress
living in chch NZ
earthquake central
Re: Ramp plates
niftyman wrote:This is coming from the guy who has trouble changing a spark plug
Not because of smarts like you but from a physical disability. God, every time you and your twin brother, * puppy, opens your mouths, you sound even more like a bigger asshat.
maddog
Re: Ramp plates
Post by maddog »
and what have you built for us lately :sad: can you even build anything fast, i understand that you are overweight= "fat kills"
Re: Ramp plates
maddog wrote:and what have you built for us lately :sad: can you even build anything fast, i understand that you are overweight= "fat kills"
Your reading comprehension skills are still non-existent. What part of physically handicapped don't you understand or are just to stupid to ever get it? :jack: Oh and once again you prove my point about you and your twin.
maddog
Re: Ramp plates
Post by maddog »
and you have no concept of with- knowledge speed is unavoidable
