New member wants a few more MPH
Re: New member wants a few more MPH
heck yea bring it in the house
i put newspaper down to soak up any oil or gas i may spill
generally i drain all the fluids from the motor before i bring it in to work on it. the motors are really easy to take off just so you know. you could bring the motor in to work on it then bring the frame in seperately
Brought my tw in a motel room once. Some people carry their scooters inside and then down to the basement. That is where I had to go to get my first jog.
You could also get a big broiling pan or the rectangular oil drain pans. That way the center stand will not puncture. Through to the carpet.
Here are some pics of my progress
- still needs cleaned
- exaust.jpg (35.78 KiB) Viewed 5746 times
- best pic I could get of stock airbox cover with restriction removed
- airclean unres.jpg (40.01 KiB) Viewed 5746 times
- with tab
- airclean res.jpg (43.15 KiB) Viewed 5746 times
I think I might have some flat spots
- variator.jpg (48.75 KiB) Viewed 5745 times
- swimmingfree
i wood like to see the other side of the verater as well as a side vue of the ramp plate..
That variator is not stock.
def not stock and its worn out...ordering a Keli from daywot when he gets back from vacation
- var side.jpg (56.98 KiB) Viewed 5745 times
- ramp plate.jpg (51.5 KiB) Viewed 5745 times
view of the face...doing a compression test as soon as it warms up out there
- var face.jpg (71.47 KiB) Viewed 5743 times
did a compression check...35-40psi. Going to pull the cylinder and check rings...what a bummer
- swimmingfree
it cant be a minamum is 90 to 100 just to have it run ...eather you did something wrong or the tester is bad...
it cant run a 34 to 40 and run ..
gage setup was bad...found a leak in the hose after I pulled the jugg off...brain fart. Messured the ID= 1.535" rings have a 0.029 gap. Going to hone the jugg and install new rings. Wasn't to bad on carbon buildup...that suprised me cause my Daughter in law ran it without a muffler.
- swimmingfree
clean the ex port as well.
what was her top speed with out the pipe????????????
She said she could get it up to 30mph but she was only 110 pounds. I could only get about 23mph untill I cleaned the carb and added the new muffler.
She did quite a number on it...broken sparkplug cap...lost the airbox cover. I'm enjoying the rebuild though. I may seem dumb but I learn quick.
