45mm bore
Pierce ramsay
Re: 45mm bore
Post by Pierce ramsay »
10gram wieghts in my vari an the power jet is disabled should I go to 11grams or 10.5grams
Pierce ramsay
Re: 45mm bore
Mystic wrote:you might try different weights or springs. with the ruima vari with 9.1 gram weights i got to 45ish at about half throttle
what kind of springs? the big spring in my clutch is a 1,500 and i believe that my 3 smaller springs are 2,000 springs i believe.
Mystic
Re: 45mm bore
Post by Mystic »
i have no idea about the springs as my bore doesnt put out much power, so havent really tried installing springs i dont quite understand how they work combined with the vari
Pierce ramsay
Re: 45mm bore
whats the best pipe for my set up? im shooting for great top end speed! :)
she is also a * to start when below 50degrees any help on that level would also be great!
Re: 45mm bore
Pierce ramsay wrote:whats the best pipe for my set up? im shooting for great top end speed! :)
Richen up the idle mixture anywhere from a 1/8 to 1/2 turn (screw in the mixture screw).
Mystic
Re: 45mm bore
Post by Mystic »
for the price the v8 you have is probably your best bet most of the other pipes are made for 72cc and up
Pierce ramsay
Re: 45mm bore
Awesome thanks guys
