Part does not exist
TikiMan
Part does not exist
Post by TikiMan »
Ive looked at two websites and the gentleman at Honda could not locate it on his screen. Im looking for the rear brake pin that bolts through the transmission. Not the one that attaches to the brake cable, the stationary pin. Any clues where to look or can I just replace it with a bolt and seal it up with some rtv?
88 SA 50- Af16e swap
87 Se 50 - 01 Af16E build
evilone
Re: Part does not exist
Post by evilone »
That sucks...haven't heard of that one before. Did it break off or fall out? Just use the front brake?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
TikiMan
Post by TikiMan »
I had the cases sandblasted and when I got home and looked at it. I noticed that the peg was not there. Its not in any of my bags of hardware.
Which scooter?
Red Eft Performance
Post by Red Eft Performance »
TikiMan wrote:Ive looked at two websites and the gentleman at Honda could not locate it on his screen. Im looking for the rear brake pin that bolts through the transmission. Not the one that attaches to the brake cable, the stationary pin. Any clues where to look or can I just replace it with a bolt and seal it up with some rtv?
Number six in the diagram? http://www.babbittsonline.com/honda-mot ... GS7XF0900B
Red Eft Performance
View products click => Here
Post by eliteguy50 »
If it is for your af05, I have an extra. Lmk.
Honda CAM, RR. BRAKE 43141-GR0-010 $13.96
It is used on 27 different models of the SA50 and SA50P.
evilone
Post by evilone »
Red Eft Performance wrote:Number six in the diagram? http://www.babbittsonline.com/honda-mot ... GS7XF0900B
He said it's not the one that attaches to the brake cable, the stationary pin so i doubt it's #6. It's not even in the diagram. It's the pin on the other end of the brake pads.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
The pivot point, right?
imomo713
Post by imomo713 »
Its called the anchor pin. Weird it has been overlooked in the parts microfiche, but I think that was common with alot of vehicles (no oem replacement parts) I would guess its a reused part throughout many models tho.
I dont think you'll be able to use a regular bolt since it bolts on the inside of the trans case, looks to have an o ring so that no oil leaks to other side of case.
edit: quick search has ebay link with pic, top left http://www.ebay.com/itm/Honda-Elite-50- ... vi-content please note its for sb50 but they all look the same
84 Honda NN50 Gyro
84 Honda NH125 Aero
86 Honda NB50 Aero
90 Honda SK50ML AF27 Dio
92 Honda SZ50MN AF24 Tact
93 Honda SA50P AF05E Elite SR
94 Honda SA50R AF16 Elite SR
05 Honda Met->Ruckus
07 Honda NPS50 Ruckus
09 Yamaha Zuma125
Yes, that is the one I'm thinking of.
TikiMan
Post by TikiMan »
yep thats it. i have the cam it goes into the rear location but the front one is missing.
TikiMan
Post by TikiMan »
But I also have a question about a little grove in the bearing raceway.
If that hole is between the bearing and the seal, it is an oil drain.
TikiMan
Post by TikiMan »
So clean out the crude thats in it. check
