stock exhaust?
Re: stock exhaust?
Post by eliteguy50 »
Bear45-70 wrote:
b.ludwig wrote:so $500 is a garuntee to get the wheel up then i wanna do it all motor and gears kevlar belt aftermarket cdi coil all tha good s***
Being able to wheelie pretty much guarantees * poor top speed. You can not have everything.
FYI the stock CDI is not REV limited and just move your pulse generator to get the 4┬░ for free. OH and the aftermarket box is gonna leave you stranded somewhere. They die a lot.
Don't forget to account for the short wheelbase of the spree and how far back the rider weight is. A frame designed for 1.5 or 2 claimed hp and then you swap in a 9hp engine. Top speed of 55 and still pulls wheelies. The short base just makes it more sketchy. Also, remember to check your rake when relocating your shock mount.
Re: stock exhaust?
I like my 2.75*10 bridgestone hoops. They are sticky enough for the spree and they don't break the bank.
b.ludwig
Re: stock exhaust?
Post by b.ludwig »
yea 4 degress is the number i mentioned but that was the setting the box set which you recommended to not use so i was askin wat would you do
Re: stock exhaust?
b.ludwig wrote:yea 4 degress is the number i mentioned but that was the setting the box set which you recommended to not use so i was askin wat would you do
You will have to figure that out. Try degreeing the flywheel and then you will have a reference, but 4┬░ isn't much. I have found that screwing with the timing on 2 strokes will result in a burnt up engine with little if any difference in performance on a street machine. On the race track, yes I played with timing allot, on the street, no.
Re: stock exhaust?
Post by swimmingfree »
timing is some thing you shod not change on the bottom of the timing crive its the top end you need to change it..
4 degrees is a huge change 1 maybe 2 may help but your motor will run hotter ( i think ) and it will melt down as your driving it but if you only doing a 1/4 at a time shood be fine..
by the way have you put a timing lite on the motor yet ???
there is marks on the fly wheel and the holes on the pick up so it can be mover a small amount ..
b.ludwig
Re: stock exhaust?
Post by b.ludwig »
ok so i found a 48mm bbk with a 21mm carb intake mani adapter new throttle cable 16*82 secondary and its 335 bucks yay nay your thoughts
Re: stock exhaust?
Tazland001 here on the forum (chop*chop123 on flea-bay) is the only one with a BBK, a 21 OKO, manifold with adapter and gears for the Spree. So of course we like his stuff.
Mystic
Re: stock exhaust?
Post by Mystic »
do the thang, thats the best you are going to get for the spree :D i think it does 40mph maybe more if you build your own muffler
Re: stock exhaust?
Mystic wrote:do the thang, thats the best you are going to get for the spree :D i think it does 40mph maybe more if you build your own muffler
If you can find the rare es pipe. That is the best flow from a bolt on manufactured pipe.
b.ludwig
Re: stock exhaust?
Post by b.ludwig »
yup thats the guy i like the kit specially for the gears and the liitle stuff it has with it least now i know i can get it here to bout two weeks ill be ready to get one fyi taz
b.ludwig
Re: stock exhaust?
Post by b.ludwig »
ok so off topic but i wanna do some cool cosmetic stuff like pointless guages and such i have a vacuum gauge and a volts gauge i wanna add a tach tho anyone know where i can find a tach for a one cylinder
Carnie
stock exhaust?
Post by Carnie »
Try vapor trail tech computers. Has all the gauges in one.
1987 Spree
1994 Elite SR
Re: stock exhaust?
b.ludwig
Re: stock exhaust?
Post by b.ludwig »
i like and i want i think i will buy ne this pay check
b.ludwig
Re: stock exhaust?
Post by b.ludwig »
Honda - WEIGHT SET, CLUTCH
Item: 22535-GK8-325
$39.73 $39.73
as seen on hondapartshouse.com 86 spree weightset still available brand new $46 shipped
