89 elite wont runn???
Re: 89 elite wont runn???
Sure-enough there's a spec and measurement in the FSM, but the PA carb float lacks the bendable metal tab that lets you adjust it. If it's out-of-spec, replacement is the only option. Occasionally it's assembly error. It is frightfully easy to get it wrong.
Usually the problem is in the float seat. Corrosion often prevents the rubber-coned needle from blocking fuel flow when indicated. The seat can be polished up using a partially-stripped cotton swab and some polishing compound - paste wax "cleaner", or even Colgate can work great.
If that fails, the needle itself is probably worn and needs to be replaced. Even if it looks perfect, it can not work properly. Honda and the aftermarket get about $15,000. per pound of float needles, but if that's what the carb needs, there's no substitute.
abreen89
Post by abreen89 »
well i measure the float and it seems to be just over 1/2 and the manuel say it should be at 12.2 mm (.46"). And when i tip the carb upside down and push on the float there is a fraction of hesitation in the needle. But remember im a :newb: so i might be making a bigger deal of it then it is let me know what u think.
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
abreen89
Post by abreen89 »
Wheelman-111 wrote:Greetings:
i ahve an extra needle ( the thing that attaches to the bottom of the float right?) so ill try that one and ill pollish them up good can u send me a link to where i can buy one tho if i need too.
Mystic
Post by Mystic »
are you sure the float isnt in upside down?
abreen89
Post by abreen89 »
Mystic wrote:are you sure the float isnt in upside down?
well the float has to be in right side up because the flaot pin attached to it pointy end down and it does attatch to it so.........
abreen89
Post by abreen89 »
here are some pics guys let me know if it looks right..
carb 1.JPG (219.46 KiB) Viewed 5587 times
carb 2.JPG (254.14 KiB) Viewed 5587 times
carb 3.JPG (212.69 KiB) Viewed 5587 times
abreen89
Post by abreen89 »
carb 4.JPG (175.34 KiB) Viewed 5587 times
Post by eliteguy50 »
Yes, that is the proper way to assemble the float and needle.
abreen89
Post by abreen89 »
eliteguy50 wrote:Yes, that is the proper way to assemble the float and needle.
alright any other ideas on what the prob might be????
First locate where the gas is leaking from. Is it from the carb overflow? Is it from the petcock and running down the side of the hose to the carb body? Is it leaking from the bowl as in a bad seal? Is there a crack in the hose or maybe the hose is not sealing around the nipple...
abreen89
Post by abreen89 »
eliteguy50 wrote:First locate where the gas is leaking from. Is it from the carb overflow? Is it from the petcock and running down the side of the hose to the carb body? Is it leaking from the bowl as in a bad seal? Is there a crack in the hose or maybe the hose is not sealing around the nipple...
caarb isnt leaking anymore the scooter just wont runnn
Oh, so it is only running in 5 second intervals? Have you tried running it on a premix spray?
abreen89
Post by abreen89 »
eliteguy50 wrote:Oh, so it is only running in 5 second intervals? Have you tried running it on a premix spray?
well it was running for a few second but only when u put my hand over the air hole in the carb or shoot some starting fluid in it otherwise it wont start
No starting fluid in 2 strokes! It wipes the oil off everything and allows metal to metal contact. If you want to prime the engine, use a fuel and oil mix of 23 to 1.
Is the carb/intake isolator mounted properly? If upside down and/or backwards it leaks air causing a no start condition.
abreen89
Post by abreen89 »
:newb:
carb intake isolator gonna need more description remember bear im a :newb:
