okay
Cleaned carb. all the way.. even the little air passage in the float bowl
new spark plug with good fire (like arc welder)
put carb back to orginal adjustments
changed out the the fuel pump.. works greats little vaccum and still pumps good
NOW WHY WONT MY SPREE RUN..it will run when i hold my hand over the butterfly to choke it off
NIC
