I dont get it
kingkamehameha
Re: I dont get it
Post by kingkamehameha »
http://www.iwt.com.au/mikunicarb.htm
Here you go mystic this really helps alot. Good write up
Mystic
Re: I dont get it
Post by Mystic »
yea i have one, I was actually thinking about doing that. I think its the same pipe that evilone used with this bore. I think it has a leak around the first screw for the small header guard though since under the guard was covered in fresh oil when I took it off cause I noticed a drip
bakaracer
Re: I dont get it
Post by bakaracer »
I noticed that you used that same pipe on your other setup and got about the same speed so just trying to eliminate the pipe as the problem. but you do have a jetting issue that you need to get fixed first as that can cause power issues. for a cht gauge the best bang for the buck is the trailtech TTO gauge. You can get one of those for about $40 shipped. or if you want rpm,cht and mph the trailtech vapor. for $130 shipped thats hands down worth it.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
Mystic
Re: I dont get it
Post by Mystic »
That is an astute observation baka :D will definately try it out it cant hurt. it could be that the kymco pipe is made to perform at a lower band than the elite
--check the specs and the kymco zx had slightly more HP and about 1000 more rpm than the elite
Mystic
Re: I dont get it
Post by Mystic »
gps :D
Carnie
I dont get it
Post by Carnie »
Is that an app?
1987 Spree
1994 Elite SR
Mystic
Re: I dont get it
Post by Mystic »
yup for my windows powered HTC tilt2 :D it will map your ride with google maps and some more stuff but I just use it for the gps
Carnie
I dont get it
Post by Carnie »
What's the name of the app? Is it pretty reliable and accurate?
Ps, I think your battery is low. ;)
1987 Spree
1994 Elite SR
Mystic
Re: I dont get it
Post by Mystic »
since the compression is higher would this bore benefit from higher octane gas?
kingkamehameha
Re: I dont get it
Yes
bakaracer
Re: I dont get it
Post by bakaracer »
Once you switched from stock to aftermarket bore,you should have been running 91or higher octane fuel already. All the aftermarket kits for these engines are higher than 11to1 compression ratio. The instruction manual that comes with the malossi cast states no less than 95 octane fuel. The malossi cast and polini contessa is. The same class bore kit, sport street.
91 yamaha tzr 250r
kingkamehameha
Re: I dont get it
I was waiting for baka to say that. I recently got a schooling on this subject
Re: I dont get it
Post by swimmingfree »
what is your compression now ???
i do think you need to run 91 or higher octane fuel..
Mystic
Re: I dont get it
Post by Mystic »
:D I thought this to be true but I wasnt completely sure have been reading A. Graham Bells 2 stroke all day. I havent even ran a whole gallon of gas yet since installation was wating till i empty my gallon of premix before going up on the octane despite my better judgement i dont want to waste a gallon that i cant use in anything else
Mystic
Re: I dont get it
Post by Mystic »
After reading the chapter on oil/fuel I got to thinking about the lucas oil I am using. It recommends to be premixed at no more than 50:1 and is already super thin which could be causing blowby which could be a reason why I am not getting as much performance as I should. I did notice the 43mm piston i took off was not only black on top but was black around the rings and right below them. I checked my local honda and they carry klotz super techniplate and castor 927 I cant decide which one to try but I gotta change oil for sure. I have heard a lot of good things about castor 927 but has anyone had any experience with the klotz super?
