Im sellig the corsa tommorow and imgonna order a mhr aluminum. The block is all ready to be split for the boost job. Is the 2AB crank a mini crank? Who makes it?
Last edited by kingkamehameha on Sun Jan 29, 2012 5:21 am, edited 5 times in total.
Oh yeah and it also came with a set of 19x37 gears. I think thats 6.8 to one. Will a stock se50 trans work for now on this motor? Im ordering a new trans set up but i want to throw this motor in and ride its been a while.
6.8, correct. The se50 variator, belt, and clutch will work in tha af16 if you use the af16 pulley boss. The se50 gears will not work with the 6.8 gears.
8to1 or 7.58to1 at the most. you can use the se50 gearset on that motor. just swap everything even the gear cover over. that intake port on the block can be opened up more and round off the edges good too. thats the most restricted area on these motors. thats why honda went away with this design in 96.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
Let me clarify im only talking about the clutch and variator when i say se50 trans. I have a couple sets of gears i can run. I just dont have a aftermarket clutch or vari on hand. Just whatevers on my se50
kingkamehameha wrote:Let me clarify im only talking about the clutch and variator when i say se50 trans. I have a couple sets of gears i can run. I just dont have a aftermarket clutch or vari on hand. Just whatevers on my se50
yeah you can use all that stuff.
91 yamaha tzr 250r
You really think the corsa is better than the mhr? Too many people in hawaii rock the corsa i want something different. I thought both bores were similar exept the malossi mhr
Makes power 1k rpms higher. I promised the corsa would go to my buddy already.
