Boost port
kingkamehameha
Boost port
Post by kingkamehameha »
I finally cut my own boost port for the first time. Here are some pics tell me what you think. Needs a hair more filing
Mystic
Re: Boost port
Post by Mystic »
Looks clean :D What did you use to cut it?
bonesv
Re: Boost port
Post by bonesv »
Nice work, King! I did mine and then polished everything, then I learned that I shouldn't have polished anything. I sanded it all back to a dull surface again with 150 grit.
It's tuff work and my big hands hated it! Good luck with the build.
kingkamehameha
Re: Boost port
I used a carbon steel hacksaw blade and did it by hand with no saw just the blade. I got alot more control that way. I just made the blade about 6 inches long so it was easier to hold. I cleaned it up with a small tungsten file. I couldnt finish it all today. Needs a little more to be perfect
evilone
Re: Boost port
Post by evilone »
Looks good.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
kingkamehameha
Re: Boost port
I took a c*** hair too much off. I need to open the boost on the bore just a tad
Re: Boost port
C*** hair grows thick in hawaii. :surprise:
Just messin' with ya. :wink: What kinda bore is this?
kingkamehameha
Re: Boost port
Malossi bore. It was perfect before i went at it with the file d***!!!
Downsouthdio
Re: Boost port
Post by Downsouthdio »
that extra little bit you went to much gunna matter?
Honda super dio
Corsa
26mm
Sparrow
kingkamehameha
Re: Boost port
Downsouthdio wrote:that extra little bit you went to much gunna matter?
No because i opened up the boost port on my bore just a little
Dio89Elite
Re: Boost port
Post by Dio89Elite »
looks pretty good! :thumbsup:
what was your man hours to do the job? just wondering...
kingkamehameha
Re: Boost port
Mabey an hour and a half
