Seems like you're over-thinking this one - Bear pointed out it wouldn't suck air into the mix, but certainly it wouldn't perform as well with a loose fuel connection. Makes sense to concentrate on re-attaching the nipple, then you can ride for a while with the plastics off until you determine if the power loss is corrected.
If you've ever worked with solder and flux, and you're comfortable with it, that seems like the best approach. If it fits without the solder and you insert it while the solder is hot, the worst that can happen is it doesn't hold - in which case you are back where you started. If you are not comfortable working with solder and you can get a reasonably tight fit, try the thread sealer - you just need an air tight seal that won't vibrate loose easily.
I really shouldn't give advice (no expert) so take it with a grain of salt.
One other thought - make sure you work in a chilly environment so that the nipple stays erect throughout re-attacment.
