Honda Spree Exhaust to Honda elite?
- SkeeTownSpree
Hey guys,
I was wondering if I am able to put an UN-restricted 86 Honda Spree exhaust on my 87 Honda Elite?
The only reason I ask is because a friend told me I would get a little more speed with an UN-restricted exhaust.
Really appreciate anyone's help/opinion on the situation.
Thanks.
Thanks.
Why not just derestrict your restricted exhaust yourself?
1987 Spree
1994 Elite SR
1994 Elite SR
- SkeeTownSpree
Re: Honda Spree Exhaust to Honda elite?
Yea after reading the thread above mine it got me thinking. I would still like to know though if It is possible to switch the exhaust out.Carnie wrote:Why not just derestrict your restricted exhaust yourself?
Thanks for the reply!
Theoretically, I am sure it is. I know an elite e exhaust fits on a spree but I don't know if a sprees would fit on a se50p. I just dont know if it's big enough. I wouldn't think there would be any performance gains though. But try it.
1987 Spree
1994 Elite SR
1994 Elite SR
I dont think the spree exhaust will bolt on since the header angles are different. You need either an se50 pipe or a leo vince sp3 aftermarket. You cant derestrict an se50p exhaust the restriction is in the diameter of the pipe itself if I am not mistaken
Correct Mystic.
You can use an '85-93 variated 50 cc exhaust on that engine. The variated and non -variated exhausts will not interchange. The spree and elite e will interchange but the elite es is the best of the three.
- SkeeTownSpree
Alright guys,
Thanks for the reply's. I'll see if i can bolt the exhaust on, and then see if i can notice any changes.
Did something get said I missed? The Spree exhaust will not fit.SkeeTownSpree wrote:Alright guys,
- SkeeTownSpree
Carnie said to try it, but he didn't sound to sure about it. I guess I was looking for a straight answer.Bear45-70 wrote:Did something get said I missed? The Spree exhaust will not fit.SkeeTownSpree wrote:Alright guys,
Thanks Bear.
- swimmingfree
the post my help you there are photo of af16 elite se50 elite and a spree jugs http://www.hondaspree.net/phpBB3/viewto ... 22071.look at the exports. you can make most thing fit if you want to cut grind and weld .. but i dont think you can just bolt it on no..
What swimmingfree says is what I meant by theoretically. You can make nearly anything fit with enough time and effort and modification but I wasn't sure if it'd bolt on as I have never thought about it. But if you have the time and means, try it. Sorry, my post was ambiguous.
1987 Spree
1994 Elite SR
1994 Elite SR
- swimmingfree
im not sure but i think it tip ( out let ) of the expipe is smaller on the spree ( i think is 3/8 id ) and biger on the elite but i dont have a elite pipe or a spree pipe.. took of the flag and scrap the rest ..
- swimmingfree
hello all..
if some one has a spree and a 87 elite or even a af16 stock pipe please tell us the inside diameter of the expipe tip.. not the end that goes to the jug...
thank for the help ...
I just measured the outlets on a 86 spree pipe and a stock sa50 and they are both roughly the same at 13mm 0.52in hard to tell exactly since my tipe on the spree is a little squished but I think they are the same. Probably wouldnt make much diference on a stock bore to make the outlet bigger since the engine needs that extra fuel charge from the exhaust as the cylinder scavenges. Would probably be helpful to a larger stroker bore that displaces more. I have a very limited understand of how the exhaust fits into the equation on a 2 stroke either way
- SkeeTownSpree
Oh alright cool, thanks for all the help! I really appreciate it.Mystic wrote:I just measured the outlets on a 86 spree pipe and a stock sa50 and they are both roughly the same at 13mm 0.52in hard to tell exactly since my tipe on the spree is a little squished but I think they are the same. Probably wouldnt make much diference on a stock bore to make the outlet bigger since the engine needs that extra fuel charge from the exhaust as the cylinder scavenges. Would probably be helpful to a larger stroker bore that displaces more. I have a very limited understand of how the exhaust fits into the equation on a 2 stroke either way
