Sym dd w/ hona dio engine i need help please!
Mystic
Re: Sym dd w/ hona dio engine i need help please!
Post by Mystic »
:woot: I figured he would, you cant beat free international shipping and some of his stuff is priced very reasonably especially compared to daywot or jiangewayne. I got my 43mm bore kit from scooterassassins and I didnt have to do anything to it but bolt it on and havent had the first sieze
jacob789
Post by jacob789 »
yeh i agree most of his prices are quite reasonable like a standard crankshaft or a standard 50cc kit for like £32
jacob789
Post by jacob789 »
just need to ask will any of the exhausts in these 3 links work properly on my scooter if it has a 72cc polini corsa, 21mm OKO carb and gears? I think 2 of them are the same but wasn't sure. If so which one will work best? thanks
http://www.ebay.co.uk/itm/Dio-ZX-DD-Arn ... 2a185c3824
http://www.ebay.co.uk/itm/Performance-E ... 335d480b31
http://www.ebay.co.uk/itm/Custom-handma ... 335eab3a4e
Sym DD
72cc Polini Corsa
Tecnigas Next R exhaust
OKO 21mm carb
CT intake manifold
7.4:1 gearing
Koso variator w/9g rollers
Race clutch w/2000 rpm clutch springs
Bando racing belt
60+mph
Mystic
Post by Mystic »
I dont think any of those pipes would work those are stroker pipes. Your best bet for the price is probably going to be a PG Long http://www.taiwantrade.com.tw/phongeer/ ... US/399410/
jacob789
Post by jacob789 »
it doesnt work when i tried ordering off that site and i dont know where else to get one. what does the term 'stroker' mean? i always hear it being used with honda dios n stuff
Post by eliteguy50 »
Stroker means the stroke is longer.
VT sells that pipe. You can even order on the phone if you like.
jacob789
Post by jacob789 »
i also asked them before and they said they dont deliver to the UK.
When i try and order it off taiwantrade it says connect UPS failed. Any idea what that means?
And what is the 'stroke'?
thanks
Sorry, I missed the UK part.
The stroke is the distance that the piston travels (up/down). The bore is the diameter of the cylinder. The two measurements are used to calculate the engine's displacement.
bonesv
Post by bonesv »
Jacob, the Jiangwayne V-8 pipe is good with the corsa kit, my neighbor has the same set up, they will also ship to UK no problem from taiwan. Some of those V-8 pipes are different but the first one you posted back there is the real deal. Good Luck.
The first one is a 32mm. Do not use that one. Look for a 28mm.
jacob789
Post by jacob789 »
ok thanks what this one?it says specially designed for 90-150cc though
will it be better than my tecnigas?
and anyone have any idea where i could get a pg long or short tht'll deliver to the uk?
That is also a 32mm. The v8 will have a better low end than your tech. The exhaust note will not be as pingish.
Mystic
Post by Mystic »
You can try this one http://www.dynoscooter.com/Phongeer_Long_p/pglong.htm I dont know from experience but I hear the PG Long is pretty loud, you may be better off getting the 28mm V8 pipe from jiangwayne they have them for a reasonable price on ebay right now 129.00 free shipping
jacob789
Post by jacob789 »
mystic that pg long dont deliver to uk, i give up witht them, cant find any that will.
i dont really want that 28mm it looks like a standard exhaust or did u mean this one?
http://www.jiangwayne.com/scooter/p_i.php?i=61
my tecnigas is probly better than that standard looking one.
why wouldnt it be better for me to get a 32mm? would it not work properly on my setup?
thanks
Sym DD
72cc Polini Corsa
OKO 21mm carb
CT intake manifold
7.4:1 gearing
Bando racing belt
60+mph
? You don't like the 28 because of the look but you like the 32 which looks the same.
