Sym dd w/ hona dio engine i need help please!
jacob789
Re: Sym dd w/ hona dio engine i need help please!
Post by jacob789 »
na i meant this 28mm
http://www.jiangwayne.com/scooter/p_i.php?i=59
would a 32mm not work properly on my setup?
Post by eliteguy50 »
That is the j pipe. I am talking about the 28mm sectional. A 32mm is too big for your setup.
jacob789
Post by jacob789 »
ok so u meant this one then?
http://www.jiangwayne.com/scooter/p_i.php?i=61
would it be better than my tecnigas for top end?
No, that is an expansion chamber pipe. I am talking about the sectional v8. It looks just like the pipe in your ebay links except it is 1/8th smaller.
jacob789
Post by jacob789 »
oh ok
jacob789
Post by jacob789 »
im going to try and fit a single wire adjustable throttle cable myself, can i do the part of connecting the cable to the carb before connecting the other end to the throttle?
Mystic
Post by Mystic »
it is easier to screw the cable into the throttle housing then thread it down the front and back to the carb
jacob789
Post by jacob789 »
Fit my throttle cable and got about 70mph out of my scooter on some long, flat road! :happy:
jacob789
Post by jacob789 »
how can i tell if my speedo cables broke completely? its randomly stopped working, it had came out at the speedo end but i put it back in n still nothin? if it is broken wheres the cheapest website to get one?
thanks
Sym DD
72cc Polini Corsa
Tecnigas Next R exhaust
OKO 21mm carb
CT intake manifold
7.4:1 gearing
Koso variator w/9g rollers
Race clutch w/2000 rpm clutch springs
Bando racing belt
60+mph
jacob789
Post by jacob789 »
* is tht any1 no whr to get a speedo cable for a sym dd cheap?
Madman
Post by Madman »
Go to your sym dealer I doubt there is an aftermarket one. Or get a used one from some wreckers!
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
