carb leaking
No.-aL- wrote:could the auto bystarter not being plugged in cause the carb to flood? that may sound stupid but im not sure if its plugged in
that does not make sense? your carb operates by vacuum,gas can not flow with out it,I mean you see some spillage but it would only overflow if your kicking/cranking it over and the carb is parital open?-aL- wrote:never mind! it was the throttle... it just had to be adjusted... my G-Pa let me know... haha i feel dumb, i was about to drop some serious cash on it!
Remember,everyone is human,even if there stupid!
Had the same problem on my Aero 80. The O-ring gasket between the bowl and the carb body was shot. A carb rebuild kit from Sirius (http://www.siriusconinc.com) included that seal plus a needle, float plunger and main jet. Problem was solved.
I don't know if they have a kit for the spree, though.
Tom Jupille
2 X '85 Aero 50s (sold)
1 X '84 Aero 80
1 X '04 Bajaj Chetak
1 X '84 Aero 80
