Af16 gear cover question
kingkamehameha
Post by kingkamehameha »
Will the newer 2000 style fit on a 94 block? What needs to be done to make aftermarket gears fit this cover!
Last edited by kingkamehameha on Fri Feb 17, 2012 1:42 pm, edited 1 time in total.
Re: Af16 gear cover question
Post by eliteguy50 »
Yes, the cover will fit the block. The aftermarket gears need the same shims as with the '94 cover. You will need the big end axle with the '00 cover.
kingkamehameha
Yeah i got the bigger end axle. Is it normal for the clutch shaft to be able to slide right out
kingkamehameha
Also the primary gear is alot bigger than the older cover style
bonesv
Post by bonesv »
kingkamehameha wrote:Yeah i got the bigger end axle. Is it normal for the clutch shaft to be able to slide right out
kingkamehameha wrote:Also the primary gear is alot bigger than the older cover style
My experience is the primary shaft should not slide out without at least some light tapping with a mallet.
Should be same primary gear if it is stock af16, maybe it's a gear from af05 that you have? Just a suggestion. Good luck with it.
305elite
Post by 305elite »
There are two different style gear covers one has a bearing on the cover side and the other just has a hole with a washer....which one do u have
01 Elite Sr
72cc Polini Corsa
21mm Pwk carb
V8 Typhoon exh
8:44:1 gears
No, that should not happen. Measure the shaft and the bearing to see where the size if off. If you let it spin there, it will just lead to problems down the road.
What is the tooth count?
kingkamehameha
Posted a pic
The '00 has looks like an aftermarket primary. Good money there. Looks like a 6.5 primary to me but it is hard to tell with the flash.
kingkamehameha
Impossible this cover came off a completely stock motor
kingkamehameha
For sure that is a tall ratio aftermarket primary.
kingkamehameha
Tooth count us 15x33. Ive never heard if those
kingkamehameha wrote:Tooth count us 15x33. Ive never heard if those
7.6
