Best tires ?
CNI Dawg
Re: Best tires ?
Post by CNI Dawg »
Will I need a metro front brake hub as well or will the Elite fit correctly
Wish there was an easy disk brake conversion for the front.
There is no hard braking / trail braking with the stock brake - just slowing a bit
61Aand Still Having Fun !
Keeping the Dream Alive ! :)
01 Elite 50SR
CMRA #77 MCE, '03 CBR600RR - Dark Horse Racing
bakaracer
Re: Best tires ?
Post by bakaracer »
CNI Dawg wrote:Will I need a metro front brake hub as well or will the Elite fit correctly
There is a complete disc brake conversion kit by ncy. I posted that in your other thread. If you don't want to spend$750 for the kit then ebc makes brake shoes for your bike. And yes you can trail brake on these things. That's how I get through the turns faster on my bike. I use the back brake more for speed control mid apex to exit due to the power band hit on these motors. That way I can stay on the gas. If not when you let off and get back on,it will want to break the rear tire loose. So I found using the rear brake mid corner to exit eliminated that and made my mid corner to exit speed faster because I'm already at almost full throttle and my momentum doesn't stop and it doesn't unsettle the suspension from chopping the throttle.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
CNI Dawg
Re: Best tires ?
Post by CNI Dawg »
that's good info, thanks !
I would not have thought of using the rear brake that way
Found a lot of wheel & tire size info on wikispreedia
http://hondaspree.net/wiki/index.php5?t ... _Reference
If I read it correctly the Metropolitan wheels 2002 & up will interchange with my 01 elite.
It appears the hub brake drum inside diameter is the same
Doesn't say if the brake drum depth is the same
I'm hoping the hub & spacers from the 01 SA50 will work w/o modification on the Metro wheels
Guess I need to find a set & try them out
01 Elite 50SR
Re: Best tires ?
Post by eliteguy50 »
Yes, bolt on wheel swap for your elite.
live dio
Re: Best tires ?
Post by live dio »
unless you ride a mini or full stroker at sick speeds don't worry about tires!
CNI Dawg
Re: Best tires ?
Post by CNI Dawg »
It's too late for me....once you've ridden on good tires you are ruined forever
01 Elite 50SR
live dio
Re: Best tires ?
Post by live dio »
Then again, some people can run any tires and still look good :smile:
CNI Dawg
Re: Best tires ?
Post by CNI Dawg »
Not me....I need all the help I can get !!!
01 Elite 50SR
Re: Best tires ?
live dio wrote:unless you ride a mini or full stroker at sick speeds don't worry about tires!
You stick with that theory, live dio....
live dio wrote:Then again, some people can run any tires and still look good :smile:
...theywill be pointing at the ambulance saying, "there goes the guy formerly known as live dio....he sure was looking good on those janky tires."
CNI Dawg
Re: Best tires ?
Post by CNI Dawg »
bakaracer wrote:............ebc makes brake shoes for your bike...........
Am I looking for EBC #333 organic brake shoes with solid friction surface - NOT grooved???
IT looks like the front and read shoes are the same - is that correct ?
I've been running the Vesrah RJL on the race bike but doesn't look like they make a brake shoe for my 2001 SA50 :(
is the 2001 Elite 50SR the same brake shoe as the Honda Metropolitan?
If so, EBC makes sintered brake shoes which should stop better
http://www.motorcycle-superstore.com/4/ ... Parts.aspx
researching on line makes it look like they use the same shoes for many Honda drum brake applications
01 Elite 50SR
CNI Dawg
Re: Best tires ?
Post by CNI Dawg »
Just called EBC USA in California....
The guy that answered looked it up & said the Metro & 01 Elite 50SR are the same shoes
However.....they do NOT make sintered brake shoes - they are all organic :(
This is strange
Motorcycle superstore lists EBC shoes for the Metro in both organic & sintered
sintered
http://www.motorcycle-superstore.com/4/ ... =Cart_Item
organic
01 Elite 50SR
Re: Best tires ?
CNI Dawg wrote:Am I looking for EBC #333 organic brake shoes with solid friction surface - NOT grooved???
One of the aftermarket companies makes grooved shoes, out of Taiwan I think.
CNI Dawg
Re: Best tires ?
Post by CNI Dawg »
No sintered shoes at EBC
All are organic with bits of copper
THe 333 shoe is solid
The 333 G shoe is grooved
EBC explained the grooved shoes are made for dispersing water out of the drum area for off road applications
My question is - Which shoe will stop better ?? ( the solid or the grooved shoes)
My thought is the solid shoe has more braking surface but I've been wrong before
The grooved pad may allow heat & gasses a way to better escape thus keeping the shoe in contact with the drum more of the time
Please advise....my brain is aching thinking about this :)
01 Elite 50SR
Dio89Elite
Re: Best tires ?
Post by Dio89Elite »
CNI Dawg wrote:It's too late for me....once you've ridden on good tires you are ruined forever
yup agreed. I never really noticed the difference before and let my budget pick my tires, then I happen to get 'sticky' tires for my RZ350 (yes, I know this isn't a lil scoot...) and I've fallen in love with them ever since :love:
CNI Dawg wrote:I need all the help I can get !!!
me too! =) :coolcruise: especially when you ride like me. :nervous: :mrgreen:
I'm running the S1's. Thanks for sharing info, guys! I have other tires now to look for. =)
*sigh* you guys just made my 'wish' list a bit bigger... metro rims... ebc brakes... new sticky tires... :smile:
CNI Dawg
Re: Best tires ?
Post by CNI Dawg »
How do you like the Michelin S1 tires ?
They are very reasonably priced (about $25 mailorder) :)
01 Elite 50SR
