MONSTER Spree
Re: MONSTER Spree
At that price you can get the whole intake and reeds. besides those are for the Yamaha Blaster quad.
SpreeMadness520
Re: MONSTER Spree
Post by SpreeMadness520 »
the intake I have fits the same reeds as a yamaha blaster, V force are far better then the ones it came with. Just making sure those are the right reeds.
130cc Stroker
1984 Porsche 944
1965 Vespa
Re: MONSTER Spree
For a $123 dollars they better double the horsepower or they are not worth it. If they give you 1 or 2 mph I would be surprised.
bakaracer
Re: MONSTER Spree
Post by bakaracer »
SpreeMadness520 wrote:the intake I have fits the same reeds as a yamaha blaster, V force are far better then the ones it came with. Just making sure those are the right reeds.
yeah thats the one. dont run the insert that they send with it since your using it for dragracing.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
bakaracer
Re: MONSTER Spree
Post by bakaracer »
Bear45-70 wrote:For a $123 dollars they better double the horsepower or they are not worth it. If they give you 1 or 2 mph I would be surprised.
believe it or not it increases hp and torque with the 4 reed design.yeah it has 4 reeds on that cage. moto tassianari makes one for stage6 which holds the 1/8mile record on a 70cc setup which is under 8sec.
91 yamaha tzr 250r
SpreeMadness520
Re: MONSTER Spree
:2thumbs:
130cc Stroker
1984 Porsche 944
1965 Vespa
bakaracer
Re: MONSTER Spree
Post by bakaracer »
Hey just to let you know,on the block on the right side of where you mount the manifold. You have to fill in the cutout with either jb weld or aluminum. The manifold hangs over the cutout so it will leak there. Unbolt the mani and you will see the imprint on the gasket.
91 yamaha tzr 250r
SpreeMadness520
Re: MONSTER Spree
Already did baka :thumbwink: Im on top of my s***
130cc Stroker
1984 Porsche 944
1965 Vespa
bakaracer
Re: MONSTER Spree
Post by bakaracer »
SpreeMadness520 wrote:Already did baka :thumbwink: Im on top of my s***
Are you just using the base gasket that came with the mani?
91 yamaha tzr 250r
SpreeMadness520
Re: MONSTER Spree
No the intake came with a gasket
130cc Stroker
1984 Porsche 944
1965 Vespa
Re: MONSTER Spree
bakaracer wrote: believe it or not it increases hp and torque with the 4 reed design.yeah it has 4 reeds on that cage. moto tassianari makes one for stage6 which holds the 1/8mile record on a 70cc setup which is under 8sec.
What is the 1/8th mile record on a 70cc setup?
bakaracer
Re: MONSTER Spree
Post by bakaracer »
SpreeMadness520 wrote:No the intake came with a gasket
The ones that come with that mani are prone to leaking and sealing good. You need to either use copper rvt with it or buy the thick gasket paper so it squishes down to seal better. Unless you filled it in by welding aluminum then lathe it down to match the intake mount, its still uneven and that thin gasket will leak. So don't get to *! :2thumbs:
91 yamaha tzr 250r
tru72
Re: MONSTER Spree
Post by tru72 »
They dont race the 1/8 mile
One of the fastest times I have heard is from my friend Marc Grauer who help start the maxiscoot magazine. In 2006 did 7.44@78.4 in 150 meters (164,05 yards) on a 70cc set up..;)
bakaracer
Re: MONSTER Spree
Post by bakaracer »
The 7.4 sec is for the 201m. The 150m is now 6.4sec. As for the 1/8th mile time it was something I read about that I remembered on one of the parts website selling the stage6 rt kit. But isn't the 201m considered 1/8th mile? That's a little over 600ft. I know they are doing 12sec 1/4mile times
91 yamaha tzr 250r
ottoman
Re: MONSTER Spree
Post by ottoman »
220 yds in the 1/8th
