2000 honda elite S have a couple of questions on performance
lolo123
Post by lolo123 »
Well i just got a 2000 honda elite s doesnt run to bad plan on rebuilding it so far i have removed restrictor plate from variator couldnt find the washer to drill out on pipe not sure if its restricted or not. Made quite a bit of difference when plate was removed . Plan on getting a bigger jet for it and cutting out second tab on filter. Want to start small and then go bigger. Trying to get a little more top speed out of it whats a good place to start im thinkn rollers?
And if i bought the polilni 70cc bbk kit will i need a performance pipe or will i be able to modify the stock one.
The oil mixing unit doesnt work so ive been mixing gas does it hurt anything if its still on the engine and not being used.
GOT ALOT OF QUESTIONS HOPING YOU GUYS CAN HELP ME OUT THANKS
Re: 2000 honda elite S have a couple of questions on perform
New variator and rollers should be the first step :imo:
lolo123
Post by lolo123 »
whats a good weight to run on rollers and will someone please show me a pic of where to drill on the muffler i cant find the washer to drill out. My main concern is the oil pump disconnected its on the bike still so should i put a little bit of oil in it to lubricate the gear
lolo123 wrote:whats a good weight to run on rollers and will someone please show me a pic of where to drill on the muffler i cant find the washer to drill out.
you have to take it off the scooter.
It is in the head of the pipe
You have to experiment with the rollers.
Lighter is better for revs...but too light wont let the scooter shift correctly to the top gear.
buy a multi pack and play around
odinxxix
Post by odinxxix »
i use rollers from polini 7.7 gram or mollasi 7.5 gram. and the pump needs to be removed and plugged with a plug from vtcycles or find a used one that works. i upjetted to #78 after all restrictions were removed.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
evilone
Post by evilone »
lolo123 wrote: And if i bought the polilni 70cc bbk kit will i need a performance pipe or will i be able to modify the stock one.
Stock can be used
lolo123 wrote:The oil mixing unit doesnt work so ive been mixing gas does it hurt anything if its still on the engine and not being used.
How do you know it doesn't work?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
lolo123
Post by lolo123 »
oil light was on when i got it and the line that goes to the carb is not connected to carb can i just plug the line that goes into the carb and pour some oil in the resivor and call it good? Cause the oil system is still all on there
evilone
Post by evilone »
Sounds like it is indeed inop. It will/may seize in the future and might damage the crank. You could pull it out and grind the gears off it so it doesn't mesh with the crank. Better yet get a $10 plug.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
live dio
Post by live dio »
you can keep the oil pump wired on full like i have done for 76,000 mi. dou all mods at the same time otherwise your a rookie :confused:
