I would like to take a moment to introduce you to "felisha"
What would you say is the quickest least expensive upgrade i can do?
Poll ended at Tue Feb 21, 2012 3:18 pm
Exhaust
0
No votes
Big Bore kit
0
No votes
Variator
9
100%
Gears (if so what ratio)
0
No votes
carb.
0
No votes
Total votes: 9
Beansdaddy09
Post by Beansdaddy09 »
Felisha is my scooter shes an 87 honda elite se50 and she is heavily restricted. felisha needs help in many areas, as you will see by my pics im on top of the cosmetics part but i need gears, exhaust, and any other items recommended also need a large bore kit. if you have a link for products that will work with my model please let me know and i hope these pics come through
felisha all ripped apart being repainted
moped skeleton.jpg (138.51 KiB) Viewed 3320 times
devenex
Re: I would like to take a moment to introduce you to "felis
Post by devenex »
How is the exhaust restricted? Is it a washer or a narrower section of pipe?
You can just grind the washer out if thats whats there.
Also, gears are a bit tricky for the AF05E motor. You can get aftermarket, but they're a pretty steep ratio (don't remember off the top of my head, sorry), or you can swap over the entire trans from an AF16E and then use aftermarket gears for that motor.
1986 Spree w/ '87 SE50 motor
arnada
Post by arnada »
she sure looks hot naked!!! ;)
Post by eliteguy50 »
Variator first, then the pipe. Pipe has diameter restrictions.
Beansdaddy09
You are right she does look good naked. i was told to take a drill put it into the exhaust and drill out holes on an angle, but im nervous to do that
live dio
Post by live dio »
never drill the exhaust, leo vinci makes the sp-3 exhaust it should fit your scoot.
Beansdaddy09 wrote:You are right she does look good naked. i was told to take a drill put it into the exhaust and drill out holes on an angle, but im nervous to do that
Don't drill it. Replace it with the proper exhaust. Even a stock se50 pipe would be good.
