Spree tires
1CrazyMoFo
Spree tires
Post by 1CrazyMoFo »
I know they've been talked to death, and on some my other motorcycle boards every time someone posts about oil or tires a kitten dies. Well, I done some searching, come up empty handed and I don't like cats so here goes.
I think Western Power Sports send me the wrong tires. They're golden boys 80/90 ~ 10's, they look really really big for my little 85' Spree. I had told the boss to order the 2.75's....but I swear these look more like 3.00's.
Fit or not I guess is the question??
Thanks in advance,
Peace,
Frank
?? Sears Allstate Compact
85 NQ50 Spree
86/2001 CMX Rebel (Daughters)
65 XLH 900
75 GL 1000
ute
Re: Spree tires
Post by ute »
2.5 or 2.75 will fit
3.0 I believe will fit front but not rear
1CrazyMoFo
Re: Spree tires
Thanks, I kind of figured so, just needed to hear from another source.
Peace,
Frank
85 NQ50 Spree
65 XLH 900
75 GL 1000
CNI Dawg
Re: Spree tires
Post by CNI Dawg »
61Aand Still Having Fun !
Keeping the Dream Alive ! :)
01 Elite 50SR
CMRA #77 MCE, '03 CBR600RR - Dark Horse Racing
devenex
Re: Spree tires
Post by devenex »
I thought 2.75's were the biggest that would fit up front on a spree?
1986 Spree w/ '87 SE50 motor
Dio89Elite
Re: Spree tires
Post by Dio89Elite »
3.00s can fit but they can be a PITA to mount on the tiny rims.
also, depending on what your setup is (i.e. height of current shock),
you just need to be aware of any clearance issues. I've seen some setups that just barely fit. :surprise:
1CrazyMoFo
Re: Spree tires
80/90~10's or 2.75~10's (same tire) fit, you have to angle the back a little.
A lot of my confusion was info got from a friend and the thought that I had stock tires.....but in the real world it had a 2.75 on the back and a 2.50 in the front.....
I made an assumption
I of all people should have known better.
If only Wikispreedia covered tire sizes or did I miss it?
Peace,
Frank
85 NQ50 Spree
65 XLH 900
75 GL 1000
fastplastic
Re: Spree tires
Post by fastplastic »
all tires are not the same size differs between brands, a 80/90 should fit front and rear and a 90/90 should fit the rear some one here should be able to correct me but im pretty sure im right...
Re: Spree tires
fastplastic wrote:all tires are not the same size differs between brands, a 80/90 should fit front and rear and a 90/90 should fit the rear some one here should be able to correct me but im pretty sure im right...
oh you are correct sir. :smile:
I am pretty sure a 90/90 only fits dio/sprees :wink: 2.75 is the largest you wanna go on a stock spree.
A 3.00 tire will not fit between the front forks of a spree.
A 3.00 tire in the rear will rub the stock air box and possibly the case on a spree.
Dio89Elite
Re: Spree tires
1CrazyMoFo wrote:80/90~10's or 2.75~10's (same tire) fit, you have to angle the back a little.
80/90~10's should be, for the most part interchangeable for the 2.75~10s.
Please be aware that there are minor differences between the two,
just as they are between different brands.
The circumference of the metric tires are sometimes wider,
resulting in a slightly fatter tire.
Bilbobaker
Re: Spree tires
Post by Bilbobaker »
I know this an old thread but I put a 3.00 x 10 on my 87 Honda Spree in the front with absolutely no trouble at all.
The ride is much better too.
I don't know if I will even try the back.. just put the tire in the fender well without the rim and is seems pretty snug and might just rub.
Plus I don't want the higher gear ratio from the bigger tire.
37 mph is plenty fast on this little tiger and it takes a block to get it there...
Bill
