soft seize?
iceman77
Re: soft seize?
Post by iceman77 »
evilone wrote:You need to remove the fan and stator to get to the seal. The oil pump side is the same side as the variator, stator is on the other side.
10-4... i'll check that out tonight.
TJ
evilone
Re: soft seize?
Post by evilone »
Heres a pic of the stator side. Fan, flywheel and stator.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
iceman77
Re: soft seize?
Post by iceman77 »
i checked the seal on the starter side. it's good. i can't figure out why my compression is so low so i scored another block for 30 bucks. hopefully i can have it together by middle of next week and see how she does.
TJ
Re: soft seize?
Post by swimmingfree »
have you done a ring end gap.. on the old girl????
bakaracer
Re: soft seize?
Post by bakaracer »
Are there any scratches or score marks on this bore? Did you use a new head gasket when you installed it? There must be something your not seeing or is being overlooked to have such a huge compression lost or the gauge is now not working right. Did try another gauge? Or put a little oil in the spark plug hole then check compression to see if it comes up?
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
iceman77
Re: soft seize?
Post by iceman77 »
bakaracer wrote:Are there any scratches or score marks on this bore? Did you use a new head gasket when you installed it? There must be something your not seeing or is being overlooked to have such a huge compression lost or the gauge is now not working right. Did try another gauge? Or put a little oil in the spark plug hole then check compression to see if it comes up?
I agree. there's some reason why it has that low of compression. The bore looks good. and yes i had a new head gasket on. i didn't put any oil on the plug hole. i forget about that trick.
TJ
Re: soft seize?
if you put oil on the inside of the jug and piston when you put it together more oil wont help ..
iceman77
Re: soft seize?
Post by iceman77 »
new to me motor. got it free
new motor.jpg (43.99 KiB) Viewed 6111 times
iceman77
Re: soft seize?
Post by iceman77 »
would it do me any good to do any intake porting while i got it off?
Mystic
Re: soft seize?
Post by Mystic »
You would need to split the cases if you are going to port the intake cause the shavings get everywhere and you dont want that stuff inside the crankcase when you run the motor cause it can score the piston and cylinder walls
iceman77
Re: soft seize?
Post by iceman77 »
Mystic wrote:You would need to split the cases if you are going to port the intake cause the shavings get everywhere and you dont want that stuff inside the crankcase when you run the motor cause it can score the piston and cylinder walls
yeah, that's why i was wondering if it would be worth it to do.
TJ
Mystic
Re: soft seize?
Post by Mystic »
unless you have a crank tool it is difficult to get it pressed back together. It can be done but its not easy and you run the risk of damaging something
iceman77
Re: soft seize?
Post by iceman77 »
Mystic wrote:unless you have a crank tool it is difficult to get it pressed back together. It can be done but its not easy and you run the risk of damaging something
No crank tool here. looks like she's staying the way she is. thanks mystic.
TJ
Mystic
Re: soft seize?
Post by Mystic »
personally I wouldnt let lack of tools stop me you just have to use your head and take it easy. I used a rubber mallet and pieces of wood to put my cases back together :D or you could call around to some engine shops and see how much they would cahrge to press them back together once you enlarge the intake
Re: soft seize?
i use the bolts to do it the long ones off the jug first and take it slow and keep it square and even..
