soft seize?
- swimmingfree
Re: soft seize?
dingle berries?????
Re: soft seize?
sure why not.swimmingfree wrote:dingle berries?????
- Trafficjamz
Re: soft seize?
You said the plug was dry...
Try putting a little premix right in the spark plug hole and see if it fires.
The clicking you heard to day was just your starter relay...cause your battery is dying
Re: soft seize?
Trafficjamz wrote:You said the plug was dry...
i had jumper cables on it that's why i thought it was weird.
TJ
- swimmingfree
Re: soft seize?
starter dont last for ever ... thay get hot and die ..
what the gap on the plug ????
Re: soft seize?
swimmingfree wrote:starter dont last for ever ... thay get hot and die ..
brand new plug. wouldn't the gap be correct?
TJ
- swimmingfree
Re: soft seize?
spark plug gap set it to the minamum by the book..
Re: soft seize?
the plugs come pregapped, try trafficjamz suggestion, splash a little premix in the sparkplug hole and try starting it sometimes it needs a little help after installation of new parts
Re: soft seize?
Never assume the plug is pre gapped to spec. What if the box got dropped. It could change the gap.always check it before install. There are other motors that use these plugs that have different gap specs.Mystic wrote:the plugs come pregapped, try trafficjamz suggestion, splash a little premix in the sparkplug hole and try starting it sometimes it needs a little help after installation of new parts
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
Re: soft seize?
ok i have my laptop w/ me beside my bike...
i tried putting some premixe in the plug hole. still nothing.
TJ
Re: soft seize?
plug gap is .024 i checked it.Mystic wrote:Never assume the plug is pre gapped to spec. What if the box got dropped. It could change the gap.always check it before install. There are other motors that use these plugs that have different gap specs.
TJ
- swimmingfree
Re: soft seize?
do you get a sputter out of it????
did you take off the fly wheel??
Re: soft seize?
So then that's sounds like your having a spark issue. Either timing is off or the spark is weak. Check connections to the coil and clean the terminal. Check tthe coil wire to plug cap. Unscrew the cap and check to see if the wire is burnt. If it is then cutoff the burnt end and screw the cap back on. Also check the green gound wire from the stator that bolts where the starter is. Make sure the bolt is tight or if the wire is not cut. Check the fuse where the battery is at too. Just try to eliminate stuff that might cause it not to have spark. Make sure the spark is strong at every arc. If its strong then soft then strong or just stays soft on the spark then that's why its not starting.iceman77 wrote:Mystic wrote:the plugs come pregapped, try trafficjamz suggestion, splash a little premix in the sparkplug hole and try starting it sometimes it needs a little help after installation of new parts
TJ
91 yamaha tzr 250r
91 yamaha tzr 250r
