intake port
FullRace808
intake port
Post by FullRace808 »
as i was building my 120 stroker. i was porting my intake and i thaught to my self, will it be better if i cut out the line in between the intake and make it bigger.
so instead of having 2 squares in the intake. will it be better to cut the thing in the middle of the intake so it makes the intake bigger? will it be better?
kingkamehameha
Re: intake port
Post by kingkamehameha »
Why dont you give it a try and let us know how it goes
Haha
evilone
Re: intake port
Post by evilone »
FullRace808 wrote:will it be better?
I don't know....weaker, yes.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
bakaracer
Re: intake port
Post by bakaracer »
You don't want to cut that brace out. It holds the top section from flexing when it gets hot. Plus its only about 1mmto1.3mm thick anyways. Why risk it leaking on top for that extra 1to1.3mm. Not worth it.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
Re: intake port
Greetings;
Someone else here ax-ted that question about 2-3 years ago. A Respected Forumista replied:
nnnNOOOOOOOOoooooooo
Evidently someone (or several) thought the same and lived to regret cutting out that little brace. It is a pretty long floor right where the hot part of the case meets the cold. Don't do it.
tru72
Re: intake port
Post by tru72 »
bakaracer wrote:You don't want to cut that brace out. It holds the top section from flexing when it gets hot. Plus its only about 1mmto1.3mm thick anyways. Why risk it leaking on top for that extra 1to1.3mm. Not worth it.
Dio89Elite
Re: intake port
Post by Dio89Elite »
no
and can't explain it any better than what bakaracer already did. =)
(thanks bakaracer)
kingkamehameha
Re: intake port
Do it! Makes your bike action
paulpauly7
Re: intake port
Post by paulpauly7 »
King you tell other people not to be a D I C K in your threads and here you are doing the same thing whats up with that?
kingkamehameha
Re: intake port
Blah
veedubh20
Re: intake port
Post by veedubh20 »
Why do you want to build dio 120, it because you want smoke, spank animo jog motor? Come on. Get real! :lol:
bakaracer
Re: intake port
Post by bakaracer »
veedubh20 wrote:Why do you want to build dio 120, it because you want smoke, spank animo jog motor? Come on. Get real! :lol:
here is an example of a dio smoking and spanking a animo jog style motor. in fact this is a piaggio watercooled 15k rpm 19hp+ motor getting spanked by yours truely on a dio powered 87 elite
http://www.youtube.com/watch?v=JWYboalo ... detailpage
ON board the derbi piaggio motor bike
http://www.youtube.com/watch?v=QhlA0McbYB0
on board a vespa with a 225cc lambretta motor
91 yamaha tzr 250r
Re: intake port
Wheelman-111 wrote:Greetings;
nnnnNOOOOOOOOOOOOOO........................................................................................................periods :hi:
