96 elite Wont start, tried everything
xenoz
Post by xenoz »
Its getting spark, carbs clean as a whistle and getting gas, by starters got good res and works properly, exhaust is good, air cleaner is good.
I'm stuck it just turns over forever. I really have no idea what to even check next.
ragtop89
Re: 96 elite Wont start, tried everything
Post by ragtop89 »
Do a compression test?
83' Aero NH80
86' Yamaha Riva 125Z
xenoz
Post by xenoz »
Yeah, just waiting for the gauge.
What if the compression's good though? :/
xenoz
Post by xenoz »
compression just above 100...
Post by swimmingfree »
bad plug or gap to big or small..
give it a prim..
did you do the test at wot???
xenoz
Post by xenoz »
Whats a prim?
and I don't know what wot means
I did the compression test by holding the throttle open and trying to start it.
ragtop89
Post by ragtop89 »
I thought 100 was low? My 84 Aero 80, way different though, is at least 142 - 200.
83' Aero NH80
The manual says 114 to 171 PSI. so you are low.
However I think it should run at 100 PSI. Have you tried priming the engine with a shot of gas mixed with oil at a ratio of 31 to 1?
xenoz
Post by xenoz »
compression was right around 114
Haven't tried priming it, can you explain how to do it?
xenoz wrote:compression was right around 114
Take out the spark plug
squirt a little premix in the hole
put the plug back in
try to start it. :wink:
xenoz
Post by xenoz »
Still just turns over
ragtop89
Post by ragtop89 »
Is there oil in your crankcase, or an abundant amount on top of your piston?
83' Aero NH80
xenoz
Post by xenoz »
ok so I sprayed some starter fluid in the air intake on the carb and when I choked it with my hand it started right up.
It won't stay running though unless I keep chokin it, so it looks like it IS the by starter?
Change the spark plug with a new one.
FYI, you can squirt the priming fuel into the carb or even into the air box inlet.
If the new plug and priming do not work, check the ignition timing.
