Firing problems.
Okil69
Re: Firing problems.
Post by Okil69 »
i took it off earlier.
2004 Vento Zip R3i Turbocam
If you have the plug out and touching unpainted metal while you kick it, you should be able to see if it is sparking.
That will eliminate the key switch, kill switch, pickup,cdi,and stator as your problem.
Okil69
Post by Okil69 »
then what would my problem be?
Okil69 wrote:then what would my problem be?
I suspect that running it with no airbox has caused your engine to run lean (very hot)
You may have caused some damage to the piston and rings. :sad:
Lets hope not.
A compression test will let you know if any internal damage is done.
Mystic
Post by Mystic »
How does that song go....another one bites the dust :P the impatience of youth....hope its nothing serious
bakaracer
Post by bakaracer »
So you kept riding it even though I suggested you not till you got the bigger main jet. I bet the motor went KABOOM!!!
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
Post by swimmingfree »
did you ever up the jet ???
Okil69
Post by Okil69 »
ok. i put a new spark plug on, it sparks, then when i put it on and try to start it.... nothing. its got good compression, and i did not up the jet.
If you don't give a number, your good compression is NOT!
Okil69
Post by Okil69 »
vin number? and where is it located?
Okil69
Post by Okil69 »
wait... im such an idiot. i held my finger over the the spot where the spark plug goes and it seemed to have compression. as i said before. please pardon my ignorance
Okil69 wrote:wait... im such an idiot. i held my finger over the the spot where the spark plug goes and it seemed to have compression. as i said before. please pardon my ignorance
That tells you nothing. An engine with 40 PSI compression will blow your finger of, but will NEVER run. Either use a compression gauge and check it properly or Image
Okil69
Post by Okil69 »
i dont have a compression gauge
Okil69 wrote:i dont have a compression gauge
Then get one because without an actual number your are at the end of help.
http://www.harborfreight.com/flex-drive ... 92697.html
