72cc polini not running at its full potential
have a 99 elite installed bbk 8 4 1 grears keli clutch and keli variotor. It will get up to about 35 and im not pushing many rpms at all. I tryed running a 88 main in it and it was way to rich so i drill out the stock 68 to about a 70 somethin and i got a lot more noticable power. It just gets to a certain point and wont kick into high rpm. Any suggetions im running close to 280 on cht. i was thinkn maybe clutch spring isnt going out all the way are i need to go to a smaller jet. IM running stock carb and exhaust and intake. I hope somebody can help me summer is almost here!
- kingkamehameha
Re: 72cc polini not running at its full potential
Get a bigger carb and pipe and tune your trans
I went 58 mph with stock carb and pipe..... so i don't think that's the problem.kingkamehameha wrote:Get a bigger carb and pipe
More like it.kingkamehameha wrote:and tune your trans
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
So my rollers arent allowing it to hit higher rpm there 9 gram i believe?
- kingkamehameha
Try all 8 grams and i know you dont want to hear this but your wasting your time with the carb and pipe stock
What's wrong with using the stock carb and pipe? That setup can 60+ plus not eat gas. So there is nothing wrong with using the stock carb and exhaust with a 72cc setup.kingkamehameha wrote:Try all 8 grams and i know you dont want to hear this but your wasting your time with the carb and pipe stock
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
- kingkamehameha
Your right but he wants his to be at full potential thats what it says as his topic title
im not trying to get every ounce of power out of the scooter its just not getting into high rpm at when goin down the rode. It will rev up when on the stand but doesnt have any power goin down the road
what have you done to the trans? also did you make sure that the bystarter was working right?
91 yamaha tzr 250r
91 yamaha tzr 250r
running 8 to 4 to 1 gears with 9 gram weights on the keli variator i know its not tuned super well but its running at 1/4 throttle the hole time if it would just make the transititon to higher rpms this think would scream! But it only runs 30 now. And when it comes to jetting it runs better the smaller main jet running a 78 and its not getting hot running at a good temp. But on the carb leanning out the air mixture screw once you get to a certain point it starts boggin like its runnig rich again.
bystarter is working right
how did you check it?lolo123 wrote:bystarter is working right
91 yamaha tzr 250r
91 yamaha tzr 250r
those weights are way to heavy. your still using the stock center spring and clutch shoes springs in the back?lolo123 wrote:running 8 to 4 to 1 gears with 9 gram weights on the keli variator i know its not tuned super well but its running at 1/4 throttle the hole time if it would just make the transititon to higher rpms this think would scream! But it only runs 30 now. And when it comes to jetting it runs better the smaller main jet running a 78 and its not getting hot running at a good temp. But on the carb leanning out the air mixture screw once you get to a certain point it starts boggin like its runnig rich again.
91 yamaha tzr 250r
91 yamaha tzr 250r
keli clutch and stock spring ive got a 2k center spring im gonna put on tmrw and my stock 8g weight you think that will help make the transition to higher rpm
yes. leave the 9's in and put the 2k center spring and try that first.you might have to mix that 8 and 9's together 3 of each and put it every other in the variator. then your jetting is going to get lean because now the motor will be reving up. the way it is now ,when you ride the engine rpms drops after the initial takeoff and then its lugging after that huh?lolo123 wrote:keli clutch and stock spring ive got a 2k center spring im gonna put on tmrw and my stock 8g weight you think that will help make the transition to higher rpm
91 yamaha tzr 250r
91 yamaha tzr 250r
