Best crank for my Polini.
bakaracer
Re: Best crank for my Polini.
Post by bakaracer »
Trafficjamz wrote:Will the head or jug need modified the compensate for the jug being raised by extra base gaskets.
Nope! That's why they made cranks with longer con rods.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
veedubh20
Post by veedubh20 »
Get a paper sheet gasket thick one 1mm And trace it. Cut it. And use a office hole cutter punch . Taiwan. Stock crank has thicker rod and is a stock 41.4mm from Carlos.
Got my degree wheel ready. Where is the best place to get polini base gaskets?
Does the malossi crank have a longer con rod like the SEF?
bakaracer
Post by bakaracer »
No it should be stock length
91 yamaha tzr 250r
veedubh20
Post by veedubh20 »
i use digital dial caliper;....
malossi crank 41.4mm full circle... does work well on polini and malossi bore...
sef copy crank 42mm
