My 85' spree does run.. but needs some work...
abreen89
My 85' spree wont run????
Post by abreen89 »
4
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
abreen89
Post by abreen89 »
6
abreen89
Post by abreen89 »
7 spark plug plate has some metal burrs on it...
abreen89
Post by abreen89 »
8
abreen89
Post by abreen89 »
Let me know what u guys think I should do the cylinder looks good I don't see any major ware marks or scratches at all thanks guys!
abreen89
Re: My 85' spree wont run????
Post by abreen89 »
i did just noticed this on the cylinder i dont know if its how its suppose to be but i think its worth metioning.
cylinder 2.png (70.12 KiB) Viewed 6031 times
cylinder 1.png (59.98 KiB) Viewed 6031 times
abreen89
Post by abreen89 »
will the top end in this ad fit my '85 spree?
http://www.ebay.com/itm/Honda-Spree-Sco ... 3a716dbf9a
Mystic
Post by Mystic »
no it wont I dont even know why they have that labeled for a Spree, it looks like a bore for a horizontal minarelli or a china cloned gy6
abreen89
Post by abreen89 »
Alright thanks mystic
abreen89
Post by abreen89 »
alright guys after talking to taz and looking at my options i decided to get a new 41mm kit so when i get it ill put it all back together and see what happens. Thanks!
abreen89
Post by abreen89 »
Alright guys i got taz's new top end in the mail. i spent today getting everything cleaned up and tommorow going to borrow my buddies torque wrench. Question though..... is there an easy way to get piston clips in? (the clips that holds in the pin) i tried and tried i didnt want to bend the clip out of wack but i can not get them in!!! right now they are shaped lie circles and at then end is bent inward almost look like a letter e but not connected obviously. Any tips will be greatly appreciated!
Mystic
Post by Mystic »
use a pair of needle nose pliers. You can put the carb side clip in the piston with it off the conrod. hold the end that is bent in toward the center, place the other end into the clip groove on the piston then twist with the needle nose toward the end that is already in the groove to make the clip slightly smaller and it should slip into the groove
abreen89
Post by abreen89 »
Thanks mystic the piston brings tax sent me look identicle are they suppose to unthought one was suppose to be a little different then the other
abreen89
Post by abreen89 »
I GOT IT RUNNING!!!! With help from you guys of course! I torqued down the head and she started right up! Now the fun begins... Tuning! Everything seems to work except for the blinkers.... Any ideas?
ragtop89
Post by ragtop89 »
Make sure you baby it, I think you have to heat cycle that?
83' Aero NH80
86' Yamaha Riva 125Z
