Firing problems.
Re: Firing problems.
Post by swimmingfree »
how do you do this???
just enough to keep the shaft and stuff lubed.
yes on the gas 50/50 ..
Mystic
Post by Mystic »
yea use a half gallon of the gas in your tank and mix a half gallon of fresh gas should get you close. if you are not using the oil pump you need to unhook the hoses and cap off the nipples before you ride otherwise it pulls in some extra air. I think you would be better off using the oil pump with it zip tied open and an ounce of oil in the gas in the tank since you dont know much about how the engine works
Okil69
Post by Okil69 »
alright! thanks!!! ill let you guys know how it does after school lets out
swimmingfree wrote:how do you do this???
i put a small amount of 2 cycle oil in it.
2004 Vento Zip R3i Turbocam
it a pump!!!!!!!! it pump it out ???
some times you bug me !!! this is not the way!!!! you need to ether grind down the gears by a plug or use it ..
Okil69
Post by Okil69 »
gonna try trading the elite for a tao tao 150 4 wheeler and 25 bucks
Okil69
Post by Okil69 »
Well. turns out a guy was willing to trade one of his 4 foruwheelers for the elite. and i need a fourwheeler to get me around my land. Its a Kawasaki Bayou 220.
Mystic
Post by Mystic »
they suck lol but if you need parts i got one sitting in my backyard :P
Okil69
Post by Okil69 »
as a matter of fact, i need a flywheel because the magnets on the flywheel on this one are cracked and you have to jump the 4 wheeler each time you wanna ride. so i might just charge the battery on it and not worry about it. idk.
my 4 wheeler 3.jpg (39.27 KiB) Viewed 4834 times
my 4 wheeler 2.jpg (42.42 KiB) Viewed 4834 times
my 4 wheeler.jpg (40.88 KiB) Viewed 4834 times
Mystic
Post by Mystic »
what year is it? mine is complete except somone messed the wiring all up, got it in a trade so I am willing to sell you anything you need off it pretty reasonably priced too. You let me know and send me some money and I will send you whatever parts you need but I am not even going to take it apart till I know for sure you want whatever parts
Okil69
Post by Okil69 »
not 100% sure what year it is but i believe maybe an 88 or early 90's and when i eed the parts ill be sure to send u the money 1st man. exactly how much would you charge for a flywheel?
Mystic
Post by Mystic »
IDK maybe 25-30 plus shipping
Okil69
Post by Okil69 »
alright now the guy said the magnets on the flywheel were cracked. does this prevent me from being able to ride?
Mystic
Post by Mystic »
not sure, if they are broken and there are gaps then that could mess up the firing and electricals i would think
Okil69
Post by Okil69 »
he said it would start if you put it on jumper cables so im guessing the magnets are to keep the battery charged or charging.
Mystic
Post by Mystic »
have you had it running yet?
