how much is too much? modding the jug
Is it ok to cut the section at the bottom of the jug that can be seen through the intake widows in the block ?
I will try to take a picture of what I am talking about.
bakaracer
Re: how much is too much? modding the jug
Post by bakaracer »
yeah you can. look at your stroker bore as an example.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
bakaracer wrote:yeah you can. look at your stroker bore as an example.
Yeah the 125 jug has no side skirts at all.
the polini jug has very high skirts.
iceman77
Post by iceman77 »
is that my bore? if so i like the way it's looking.
TJ
iceman77 wrote:is that my bore? if so i like the way it's looking.
TJ
Yes sir. Now I am just waiting for autotech355 to send gears. tiawan is far away :sad:
some port work by jamz
side skirts compared to polini bore
bakaracer
Post by bakaracer »
if your going to leave the intake port on the block that size, at least round the top and smooth out the side more so it doesnt cause to much turbulance.
91 yamaha tzr 250r
bakaracer wrote:if your going to leave the intake port on the block that size, at least round the top and smooth out the side more so it doesnt cause to much turbulance.
I will do that :2thumbs:
kingkamehameha
Post by kingkamehameha »
Looks good traffic. What size carb and jets you planning on running? Does a block with a matched boost and ported intake port require bigger jets because there is more flow or smaller jets because it runs more efficient????!!
ported = smaller jets
I got it opened up a little more.
I will go back over it tomorrow with some cartridge rolls.
damnSA50
Post by damnSA50 »
On my Malossi bbk for the af05 the exhaust port isnt quite circular, think I should bore it out? Im thinking I should wait till I get a bigger carb first, this stock one might be the pin in my grenade.
damnSA50
Post by damnSA50 »
Oh ya traffic, I show everyone I know your photobucket race vs the honda civic or whatever that thing was. Thats a bad * scooter.
Post by swimmingfree »
hopping to see what kind of rpm and what other info you get from this motor...good read so far ... what is the gool of this motor racing ???
swimmingfreee
iceman77
Post by iceman77 »
swimmingfree wrote:hopping to see what kind of rpm and what other info you get from this motor...good read so far ... what is the gool of this motor racing ???
swimmingfreee
nope not racing but a daily driver
TJ
