That settles it! The SEF is Da Bomb. Send that now-worthless Scorpion to me for immediate uh... Disposal.
It's just not fair that the brothas from Hawai'ii get to cast off pipes we never even see on the mainland!
Scorp isnt very loud. It has a peppy dirt bike kinda sound to it. Im sticking with the scorp id rather spend the 300 on other things like a stealth vapor gauge and mabey a 26mm carby
kingkamehameha wrote:Its the smaller scorpion. I posted a pic of it with the broken flange. I dont care about the tuning. I just dont want to waste money on a pipe i wont use. Im payin 300 bucks for the sef magic
300 whoah if you don't care about the tuning, i'd stick with the scorpion.
I'd like to buy a Vapor gauge too, I think they're money well spent. =)
i'm gonna test out this fine Malossi Mhr !!! fresh high temp powder coat satin black!
scoot nasty.jpg (145.28 KiB) Viewed 50971 times
72cc polini contesa kit
oko variator with 8.5 gram malossi weights
21mm Black Oko Carb & Ct Manifold
8.44 gear
malossi MHR exhaust
Dio zx trans conversion
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
ANOTHER Unobtainium Pipe?!
I tell ya Dawgs, life just ain't fair!
So when are you going into the reselling business sir? If you do I bet you will have several customers just from one site. I need a pipe less than 150$ for a freakin af05e.. Good thing I like to weld.. booooo
Pm me about the scorpion pipe. There are guys on this site that have access to shops in oahu. The sef magic copy goes for around 250 brand new and so does the scorp
I bought the pipe from another forum member from hawaii, and no it was all rusty and needed some work. It was sandblasted and coated with a high temp powder, wich is holding up perfectly, no discoloration at all. I must say it seems as if it stay's cooler with the coating on it also.. but not def. sure. I'm very pleased with this pipe... it may not be a "top speed" pipe but it has awsome all around performance!
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
