My 85' spree does run.. but needs some work...
Re: My 85' spree wont run????
Heat cycle? taz and bear didnt say anything about that... let me know what u think.
'89 Honda Elite SB50p STOCK
Oh I am not 100%to sure. But I thought you had to break it in or something.
yea i was told to run two tanks at no more then half throttle and to as a little oil to the gas then its ready to go.
That is not heat cycling, that is break-in.abreen89 wrote:yea i was told to run two tanks at no more then half throttle and to as a little oil to the gas then its ready to go.
Bear45-70 wrote:That is not heat cycling, that is break-in.abreen89 wrote:yea i was told to run two tanks at no more then half throttle and to as a little oil to the gas then its ready to go.
yea i dont need to heat cycle it right?
You should always heat cycle an air cooled 2 stroke.abreen89 wrote:Bear45-70 wrote:That is not heat cycling, that is break-in.abreen89 wrote:yea i was told to run two tanks at no more then half throttle and to as a little oil to the gas then its ready to go.
How do I do this?
Which part in the picture holds the left (rear) brake control to the handle bar... my problem is it wont stay in the brake holder so when i start it up i have to manualy hold it which can get annoying while tuning. thanks!
- handlebars.gif (27.47 KiB) Viewed 5308 times
#17 on the left (rear) brake.
Bear45-70 wrote:#17 on the left (rear) brake.
sorry i meant which pint actually hold the brake to the handlebar is it a bolt or a pin or what i dont have the stock whatever it is and i think its causing the lever to slip out of the holder.
19
Thanks bear
Re: My 85' spree does run.. but needs some work...
Ok guys i gott her running heat cycled and two tanks of premix through her. But no that i can go wot she seems to be running a little lean and hot.. i did a plug chomp and confirmed it on wikispreedia. can i just upjet? or will carb screw tuning fix it?
You have to up jet. The screw only effect idle.abreen89 wrote:Ok guys i gott her running heat cycled and two tanks of premix through her. But no that i can go wot she seems to be running a little lean and hot.. i did a plug chomp and confirmed it on wikispreedia. can i just upjet? or will carb screw tuning fix it?
Alright which # jets do u recomend?Bear45-70 wrote:You have to up jet. The screw only effect idle.abreen89 wrote:Ok guys i gott her running heat cycled and two tanks of premix through her. But no that i can go wot she seems to be running a little lean and hot.. i did a plug chomp and confirmed it on wikispreedia. can i just upjet? or will carb screw tuning fix it?
