gummed up piston rings
Chuck
Post by Chuck »
I'm changing the piston rings on my 86 spree and can't get them out
they're all gummed up
help
please
burnt_toast
Post by burnt_toast »
get a new piston, good chance if the rings are stuck to the piston, the piston won't be any good once you put it back in.
only like $30 something for a piston at the dealer.
projects galore :nerd:
berreta22
Post by berreta22 »
If the rings arent "welded" (like they got hot and fused in the grooves) try soaking it in mineral spirits or carb dip that you can buy at the parts store..soak em for 24 hrs at least. Hope it helps. Otherwise yes, youd be better off going to the dealer and spend like 30 bucks and be done with it.
mopedman
Post by mopedman »
yea the fact that they wont come out, is a good hint that your piston isn't tooo good, how many miles on the bike?
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
