Duke250
Post by Duke250 »
Suup all need some advice. I have a friend that have had a Honda elite that has stop working a year an half ago. Now it is sitting in my garage. I have clean the carb ,change the air filter ,change the spark blug , i dump the old gas and old oil out . I've bought a new battery and change the fuse. I have tried to electric start it but not even a sign that says it will electric starts. So I tried the kick start . Nothing happen . Then I choke it with my hand it start but went dead again . I know it is not my carb because I clean it over and over . Every times I take the air filter out and choke it with my hand then put back the air filter box then kick start . It start for at least 15 second and died again. I am about to buy a compression tester to run a test. Question does it required a specific compression test ? Because I stop at auto parts today the cheapest one I saw was for $20.00.
Other questions
When I unscrew the fours screws on the top of the cylinder there is one part that seems it is glue and I can't reach the piston to look at it . How do I get the Piston out????????
When I finish running a compression test and change rings if needed would that result the fact that it can't electric start???????? :peace:
Duke250
Honda Elite Won't even start?
Post by Duke250 »
I just order a compression test kit hope it will worked .
Re: Need a quick help For my friends Honda Elite .
When you put your hand over the carb to start it, do you also twist the throttle a little bit?
are you pressing the brake, when trying to E-start?
Duke250
Post by Duke250 »
Yes when I twist the throttle and choke it . But if I don't choke it and twist the throttle there is no sign it will start . The funny thing is if I don't twist the throttle and don't choke it there is sign it will start .
dun rite
Post by dun rite »
http://www.hondaspree.net/other/SA50_88-02_service.pdf This will help with your troubleshooting.
The by starter may not be functioning properly. there is an easy testing procedure in the wiki section of the forum. http://hondaspree.net/wiki/index.php5?title=Main_Page
it's a starting place. good luck
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
Duke250
Post by Duke250 »
Is it the bystarter because I also have a honda spree and and if I kick start it . It will start with out the bystater on the carb.
I suspect the pilot jet is still dirty......go clean it again. :smile:
Follow the how to in wikispreedia
Duke250
Post by Duke250 »
thanks for the sites of the manual book . I was looking for one
dun rite
Post by dun rite »
you might need to soak the carb in a carb cleaning solution. spraying it with carb cleaner doesn't always get the very small pilot hole cleaned out. or view this topic viewtopic.php?f=3&t=22645 if you know someone with the cleaner.
arreche air filter
v8 pipe
stock gears
Duke250
Post by Duke250 »
I will try to clean it again but I had cleaned it like five times all ready with guitar string
dun rite
Post by dun rite »
you were able to get the string through the hole?
arreche air filter
v8 pipe
stock gears
Duke250
Post by Duke250 »
yes all of them except for the tiny one inside the bowls that hold the gas
ragtop89
Post by ragtop89 »
That's your pilot jet hole.
83' Aero NH80
86' Yamaha Riva 125Z
Duke250
Post by Duke250 »
I just put a picture up. Do you see where it says bystarter metering orifice . That is the only one i can't get a guitar string through .
