Basically stock with 9.8 -1 gears outcome...
Simonsr50
Post by Simonsr50 »
So I just recently installed my 9.8 -1 gears in my 2 2001 elite 50's. Motors are stock with perfect compression at just over 100: clutching is a keli variator, 2k grabbers, 1k center, airbox tab removed with I think I drilled to an 87.5 main to be safe and right now I'm running about 40 grams or so. Pulls to about 7800 rpm WOT flat ground and with my 220 lb fat * on it, I reached 49 mph gps verified. I went to a big downhill and reached 59 gps verified. Lost a little on the dig but so worth the extra mph. Anyone with similar setupsets see what you got and share...
Downsouthdio
Re: Basically stock with 9.8 -1 gears outcome...
Post by Downsouthdio »
Nice..! Stock pipe?
Honda super dio
Corsa
26mm
Sparrow
Just over 100 PSI for compression is barely acceptable since the manual specs out 171 PSI max and 114 PSI minimum.
Simonsr50
Post by Simonsr50 »
Stock pipe yes. And cbr1000 if I had 171 psi compression I'd have to run race fuel from the factory. 100psi is factory spec. I'm actually at like 107 I think.
ragtop89
Post by ragtop89 »
:crazy: :crazy: :crazy:
83' Aero NH80
86' Yamaha Riva 125Z
Simonsr50
Post by Simonsr50 »
Can someone correct me if I'm wrong. I'm no scooter genius but I think 170 is very high no????
iceman77
Post by iceman77 »
Simonsr50 wrote:Stock pipe yes. And cbr1000 if I had 171 psi compression I'd have to run race fuel from the factory. 100psi is factory spec. I'm actually at like 107 I think.
If your at 107 psi then you wouldn't be able to pull hills at the speeds you are saying
TJ
Post by swimmingfree »
Simonsr50 wrote:Can someone correct me if I'm wrong. I'm no scooter genius but I think 170 is very high no????
you may think its high but its not cheep gas is all you need at this compression when you get closer to 200 your may need prem but not at the books max ...
ragtop89
Post by ragtop89 »
I like how you assumed it's factory spec. though lol. Did you read the manual? :wink:
83' Aero NH80
chapter 3 page 7 is the info
Flash 3 was all-stock from the crank up. Didn't even drill the airbox. 9:1 gears, good clutch and 90/90 tire was good for exactly 49MPH in my case too. Don't quibble about compression. Too much variation between testers. Even using a different adaptor made a 20PSI difference in my case. My Corsa's install compression was 115 or so. It ran 69 +.
odinxxix
Post by odinxxix »
i am running 9:1 gear and a prodigy vari with 45 grams of weight, 2k grab springs, running about 48-50 mph. rest is stock, nole punched in air box #78 / 80 jet cant remember.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
Look in the manual, like I did. 114 minimum and 171 maximum. So at 107 you are below minimum and hence need a top end rebuild. Oh and no you would not have to run racing gas at 171.
kingkamehameha
Post by kingkamehameha »
Only need race gas when you have a high compression RATIO
Post by eliteguy50 »
The horsepower will limit top speed with variable belt drives. That is why the 9.8 gears get the same speeds as the 9.2:1 gears on stock bores.
