My 85' spree does run.. but needs some work...
abreen89
Re: My 85' spree does run.. but needs some work...
Post by abreen89 »
okay guys i have my aire filter lid firmly on (tighter then stock) and i intalled a new hose clamp to the airfilter to carb connection. I also heli-coiled on the carb because they were in bad shape. So i fired her up and she turned over and idled AWESOMELY. took her for a ride i was reaching 27 mph at WOT which was faster then before, but after about a mile of WOT....................... glub glub glub and died. its was like i ran out of gas.. and she wouldnt turn over so i sprayed some mix into the air filter she started up just like before and ran good after a mile (give or take) died again WTH is wrong?
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
abreen89 wrote:okay guys i have my aire filter lid firmly on (tighter then stock) and i intalled a new hose clamp to the airfilter to carb connection. I also heli-coiled on the carb because they were in bad shape. So i fired her up and she turned over and idled AWESOMELY. took her for a ride i was reaching 27 mph at WOT which was faster then before, but after about a mile of WOT....................... glub glub glub and died. its was like i ran out of gas.. and she wouldnt turn over so i sprayed some mix into the air filter she started up just like before and ran good after a mile (give or take) died again WTH is wrong?
Soft seizing, do a compression check and a plug chop.
abreen89
Post by abreen89 »
compression 105 psi
plug no. 18 on wikispreedia guide (good)
abreen89
Post by abreen89 »
bear if its soft seizing do i need to upjet? also i measure the float and it is off... would that cause my problem... and i would fix it but plastic doesnt bent and stay so i need to get a hole no float if you think that could be the cause.
That is what the plug chop is for. To tell you how much to upjet.
abreen89
Post by abreen89 »
alright ill kill it at WOT and pull the plu and post pics give me a sec
abreen89
Post by abreen89 »
alright i did the plug chop again and now it looks like number 19
martynkim
Post by martynkim »
You need to upjet too much to start and move down so you stop soft seizing. Running it too rich won't hurt anything while tuning. You have a leak somewhere. Stock bore and stock box and jet should be fine. However you can compensate for your leak by up jetting. I would start at 80, then move down.
abreen89
Post by abreen89 »
martynkim wrote:You need to upjet too much to start and move down so you stop soft seizing. Running it too rich won't hurt anything while tuning. You have a leak somewhere. Stock bore and stock box and jet should be fine. However you can compensate for your leak by up jetting. I would start at 80, then move down.
So should i just buy an 80 jet or should i buy a bunch of different ones?? wheres the best place to buy jets??
abreen89
Post by abreen89 »
:bump:
Aguacate
Post by Aguacate »
:bump:
Free bump for abreen89 who is a good guy to do business with, I just got the emulsion tube from him at a decent price.
A true ScootBro!!!
now, let's get :b2t:
Check on ebay, I saw some main jets for sale there:
http://www.ebay.com/itm/Honda-Spree-NQ5 ... 419&vxp=mt
http://www.ebay.com/itm/Honda-Spree-NQ5 ... 98&vxp=mtr
+He who dies with the most toys wins+
