- OneBulletDan
Re: Need a quick help For my friends Honda Elite .
Test your new gauge on a motor that you know runs. My first HF one said my Spree had 30 pounds, and my Met had 80. The Met runs well, and is supposed to have over 200 PSI. The Spree since has been started, and there`s no way one will even fire at 30 PSI.
it does fire when I spray that starting fluid .Then died after 15 second . I just bought some carb cleanings I will try that
Succcccccccccccccccceeeeeeeeeeeeeeeeeessssssssssssssss!!!!!!!!
Thanks all who support me with my moped . I finally found why gas was not able to get to the engine. I don't know what you call that tube . But check the picture . I had tons of dirt that stack in that small valve . Man I couldn't believe what I saw . Once I get it out . Put the valve back to get my problem is all gone. It is running all fine .
- Yep that was my problem Got half of that small tube filled with dirts
- DSC05858.jpg (125.93 KiB) Viewed 4582 times
Glad you have that fixed. Its the fuel inlet. The fuel inlet has the largest dia line. Vac and oil injection get smaller id tubesI don't know what you call that tube . But check the picture . I had tons of dirt that stack in that small valve .
Oh ok . Yeah with out you all I might not able to fix it .I was about to take it to a moped shop and let them work on it.
glad you got it figured out. How many times did you clean the carb
For something that seems rather simple carb cleaning can be so hard.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
arreche air filter
v8 pipe
stock gears
I had cleaned it like 6 times and I also used the card cleaner. There is no way that the carb clean will of clean what came out from the fuel intlet. Its was like a small pieces of rusted metal and dirt over it. SO what I did is I take the tube on the carb clean and used it to spray in every hole and try to look carefully where the the fuel will come out . The first time I clean the carb with the carb cleaner I just spray it on there and let it sit . I guest I didn't do a good job the first time.
You know this rust and dirt is coming from the gas tank....Install a fuel filter to avoid repeated trouble. Use of clear fuel line is helpfull. Tank cleaning is in order.
spray -can carb cleaner is not as strong as carb cleaner that comes in a gallon can...Berrymans brand is $20 a gallon and will clean hundreds of carbs. Compressed air is a essential part of carb-cleaning. The teeny-weeny passages that have clogged from years of sitting with gasoline in them will become impossible to clear with spray-can cleaner alone. Sounds like you are finding some of this out the hard way, but you are making progress...
Thanks man !!! . Yeah I guest I did went the hard way. Oh well I know now for next time . I was just about to take my cylinder out and go ahead and spend more money on rings for my piston because when i do the compressions text it was reading like 72psi. SO I am glad I did listening to you guys. Thanks again all who support
Hey all I have took my honda elite to a ride . It runs great but when I Shut of the engine I have gas coming out on one of those small tubes that I believe that allows air in the carb . Any idea do I need to change my bystarter ?It is locating right by the bystarter.
sounds like the carb inlet needle isnt shutting the fuel flow off. here's an article explaining the cleaning procedure for the seat, your needle may be bad as well.
http://hondaspree.net/wiki/index.php5?t ... Valve_Seat good luck
arreche air filter
v8 pipe
stock gears
arreche air filter
v8 pipe
stock gears
Gas is running out one of the vent tubes because all that crap from the gas tank is getting stuck between the float needle and seat preventing shut-off.
Dun Rite You are right the gas inlet is damage . The little point on there is broke. Now do I have to buy a whole carb. I hope I dont have to .
- IMG_1909[1].JPG (224.93 KiB) Viewed 4557 times
New carb not required, only new float needle...
Man I stop at a Honda dealers they charge me $ 17 just for that inlet . The first place I stop was going to charge me 30 bucks .
