LED street glow 85 spree
I just put in a street glow strip on my spree. I got all the parts I needed on Ebay for under $10.
- photo.JPG (122.59 KiB) Viewed 7064 times
- photo 2.JPG (29.19 KiB) Viewed 7064 times
- photo 1.JPG (40.16 KiB) Viewed 7064 times
1985 Spree
Re: LED street glow 85 spree
Love it!
Its a Super Spree! I got blue LEDs in the mail on saturday, I dig the blue lights!
Nice work! You should get a red one also and have them on strobe patern, you might pull some chick up on the road!
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
50mm BBK (tai)
V-8 pipe
- Dio89Elite
awesome price for awesome looks!
all that light coming from one glow strip?
Looking good!!!
- paulpauly7
really?
yep, just that one in the picDio89Elite wrote:awesome price for awesome looks!![]()
1985 Spree
Having led or any other kind of lights on while driving here can get you a ticket. At least you did what I did and added a switch. I use the switch on the ground side to avoid having power going through the switch and avoiding a risk of a fuse blowing. I hope you used a fuse in line.
A poor pic due to downsizing it to fit.
- IMAG0746-1-1-1-1.jpg (232.51 KiB) Viewed 6907 times
I like the sprees body style more than the elites, you should get 2 more strands and put them inside the front wheel well and the rear like mine and itll give it a halo all around. Nice spree btw!
- Trafficjamz
LoveMyHonda wrote: I use the switch on the ground side to avoid having power going through the switch and avoiding a risk of a fuse blowing.
Current flows through the switch no matter what side of the circuit you put it on.
You can ground out or " short" it and it won't matter if its a ground fed switch lol. Try that with a positive fed.
- stucinthe80z
led strip will us a very small current you can run ten of them on a one amp fuse well before you blow the 7 amp fuse that powers you spree.
If youre hooking up extra things off of the battery save yourself some real problems and use a separate fuse, dont be cheap and screw up your regulator when your wiring grounds out.
Fuse holder -7.99 and readily available at wally worlds universal
regulator - 24.99 used and weeks or at least days to get the replacement.
Use your brain and put a fuse in line with any extra crap.
